Power Antenna rebuild thread....
Old Aug 27, 2015 | 05:46 PM
  #201
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Power Antenna rebuild thread....
Originally Posted by Kspayth
Sure beats paying 200 for a rebuild.
Who is charging that? I paid $65, and that included return shipping. Steel cable repair.
Old Aug 30, 2015 | 11:15 AM
  #202
Kspayth's Avatar
Car: 1988 IROCZ
Engine: 5.7
That was for a complete rebuilt unit. Who does the steel cable repair?
Old Sep 9, 2015 | 10:52 AM
  #203
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I did the steel cable repair this weekend. Some thoughts/tips:
It's not necessary to burn/melt off the nylon, a simpler method is to take a razor blade and cut the length of the casing. Then it just peels off in one big piece.
Adding some dielectric grease to the gear seems to improve function slightly.
Over all, for the amount of time and price I would recommend this modification. Antenna seems to extend/retract better than with the nylon.
one happy camper here
Old Dec 13, 2015 | 06:22 PM
  #204
neilcase's Avatar
Car: 1987 IROC-Z convertible
Engine: 5.0
Transmission: 700R
Axle/Gears: 2:77
For testing before reinstalling from the battery here are the wire connections
For UP Grn is + Grey is -
For DOWN Grn is - Wht is +
This little tidbit of info is fantastic! Just pull apart the real connector next to the ECM and stick some paper clips into each color wire and test it. Luckily mine works perfect.
How to test a power antenna third gen camaro.
Old Dec 19, 2015 | 08:05 PM
  #205
DynoDave43's Avatar
And four months later...
http://forums.aaca.org/topic/172383-...ntenna-repair/
Sorry I didn't see your post earlier, Kspayth.
Old Dec 2, 2018 | 07:01 AM
  #206
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Not sure if this is the correct part number for our cars, but in case anyone is looking for NOS, it looks correct.
https://www.ebay.com/itm/1982-1992-C...A0Gj:rk:2:pf:0
Old Aug 9, 2021 | 09:22 PM
  #207
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
All I need is a replacement mast for my power antenna. After storing my Iroc in a storage facility, some baffoon broke off my mast. Any idea where I can get the proper mast? As you can see in the pictures, the bottom half of my mast is inside.
Old Aug 9, 2021 | 09:55 PM
  #208
AstroFirebird's Avatar
Car: 88 Formula 350 and 92 Z28
My firebird is the same way. Mast is broken. I think we're SOL on this one as I haven't been able to find a replacement mast.
Old Aug 10, 2021 | 07:20 AM
  #209
Reddragon88gta's Avatar
Engine: 5.7 L98
https://www.summitracing.com/parts/CWA-56003151
For about $90 you can get the entire motor assembly, it’s identical to the one our cars had. All you have to do is 180 the mast and splice the 3 power wires and your done. You could also swap the finial from yours and it would be impossible to tell you even switched.
Old Aug 10, 2021 | 05:30 PM
  #210
Old Aug 10, 2021 | 07:24 PM
  #211
neilcase's Avatar
Engine: 5.0
Transmission: 700R
Axle/Gears: 2:77
I have at least three fully functioning complete units. But I sell them for $225 each. You can also just google for the repair kit. They sell for $40-$60. It is a mast attached to the "fish Line" wire that retracts the mast onto the spool. You have to crack your unit in half and do the repair yourself. It's a little tricky if youve never done one.
Old Aug 11, 2021 | 02:07 AM
  #212
Are you able to wiggle down the price? OEM new sells for a heck of a lot less.
Old Aug 11, 2021 | 06:59 AM
  #213
neilcase's Avatar
Engine: 5.0
Transmission: 700R
Axle/Gears: 2:77
if that is a true fit OEM that is a smoking price and I'd jump on that if I needed one. The true fit OEM usually goes for upper $200's and more. There is an "OEM" one there that doesn't fit correctly. I know because I ordered one and sent it back which is why I decided to rebuild mine. The mast tube is bigger, you have to mount it slightly differently and the original bezels don't screw onto it either. That was a few years ago so maybe I'm out of touch now. You can DM me if you're interested in an original that has been rebuilt. I need to get them out of my garage so I'll consider a decent offer on one.
Old Aug 11, 2021 | 09:31 AM
  #214
Engine: 5.7 L98
It's true OEM fit, the fender grommet and twist on bezel fit perfect with the Crown unit. Neil I think I saw the one you mentioned on a Firebird centric parts place and it looked really close but the top of the mast looked different and could cause the bezels not to fit, they also wanted $200 IIRC.
I still can't believe the aftermarket has not come up with a exact replica complete with correct length wire/plug and antenna wiring, but at least the Jeep/Crown unit works with a minimal of modification.
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
sreZ28
Aug 14, 2015 07:48 PM
