question about wheels??
Old Jun 8, 2002 | 09:11 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
pic:
http://photo.starblvd.net/~hwcoll95p...g?i=1023534284
RPO from center console:
LB9 Engine, 305ci, 195hp (IROC-Z only) 8,925(works)
K68 : GENERATOR,105 AMP
UA1 Battery, heavy duty
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
TPI Prom Identification Numbers
(89 5.0-F M/Trans(M39) Fed, 3.08(GU4) 16129337 9338ANYR )
Drivetrain:
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
GU4 : AXLE REAR, 3.08 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
Suspension:
J50 : BRAKE SYSTEM, POWER
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
PF2 : WHEEL, 15 X 7, ALUMINUM
16P : WHEEL COLOR, BRT WHITE (91)
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
Interior:
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 Power Door Locks (works)
A90 Power hatch Release (works)
B35 Floor Mats, carpet insert, two rear (missing)
B48 Luggage Compartment Trim, deluxe 23,150
UQ1 : RADIO PROVISIONS, FOR STEREO
UM6 Radio, stereo, cassette, clock, seek/scan (has pioneer now/CD coming)
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
B18 : ORNAMENTATION, INTR, DELUX
D34 : MIRROR, VISOR VANITY
D7L : GEAR, SPEEDO DRIVEN
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
NP5 : STEERING WHEEL, LEATHER WRAPPED
N33 : STEERING COLUMN, TILT TYPE
U25 : LAMP, INTR, RR COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U26 : LAMP, INTR, ENG COMPT, COURTESY
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
72W : TRIM COMBINATION, VINYL, DK CARMINE (W)
72C : TRIM COMBINATION, CLOTH, DK CARMINE (C)
72I : INTERIOR TRIM, DK CARMINE (91)
729 : SEAT BELT COLOR, DK CARMINE (9) (91)
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
K34 Speed Control, with resume (not working/something with wipers???)
Exterior:
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
A01 Tinted Glass, all windows
WW8 : APPEARANCE PACKAGE(BRIGHT RED), AERO #8
W62 : ORNAMENTATION, AERO PACKAGE
1SC : PACKAGE, OPTION 03
B84 Moldings, body side
B91 Moldings, door edge (black) 22,801 (red after repaint)
81Q : MOLDING COLOR, BRIGHT RED (91)
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
D35 : MIRROR, OUTSIDE REAR VIEW
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
T93 : LAMP, TAIL & STOP, SPECIAL
TR9 : LAMP, GROUP
T96 : LAMP, FOG
DE1 Louvers, rear window 6,734 (missing)
question about the wheels,how hard are they to find in this???searching has got me nowhere,1 has pretty bad road rash!!
Thanx in advance,charlie
Old Jun 9, 2002 | 12:33 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
maybe...
my post was toooo long??anyway RPO:
i can't seem to find just 1 to replace one that has some curb rash,and the wheel color bright white???????
Old Jun 9, 2002 | 09:05 PM
Blue502's Avatar
That wheel color code in the decoder is incorrect for your year, though I'm not what the correct translation would be for that code. Those 15" wheels were available in '89 and '90 (in silver or gold trim), and are probably available from most thirdgen wreckers (try Hawks or Thirdgenparts), though may be hard to find elsewhere. Classifieds would be worth a shot. Swap meets might be another source.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
