HP ratings for 305TPI
Old Jul 5, 2002 | 09:04 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
My friend might be looking at a 91 Z28, 305 TPI automatic- I told him 205hp. To learn a little more I browsed the the tech section.
Why are the 91-92s 305 TPI hp peak is at 4200RPM?
Shouldn't it be 4400RPM?
How did a 205hp rating come about for a 305 TPI Auto??
All other years were 190 hp (except 85)
Did they give it the same cam as the 5spd?
What's the redline on a single cat 5spd 305 TPI-
91-92?
What's the redline on a auto 305 TPI 91-92??
If a single cat 5spd 305 TPI was rated at 205 hp
in 91-92....why is an 87 rated at 215?
Thanks for any help
Old Jul 6, 2002 | 10:16 AM
91zeder's Avatar
The 205hp engine is exactly the same as the 230hp 5-speed. Only difference is the sinle cat(205hp) vs dual cat 230hp.
My car redlines @5000rpm.
I believe that the 91-92 lb9 was the strongest and best 305 GM has ever produced.
I am very impressed at the power of my engine but I wished all 91-92 would have had the dual cats since it was worth 25hp and 15tq.
i
Old Jul 6, 2002 | 11:35 AM
avro206's Avatar
Car: 89 Formula
Um...why does your car redline@5000rpm then?
How can dual cats up the redline to 5500?
And why did my old single cat 87 305 5spd TPI have 215hp VS 205 for 91-92?
This whole thing seems weird.....
Old Jul 6, 2002 | 11:59 AM
iroc22's Avatar
The whole exhaust system was bigger on the old single cat setups. Manifolds and Y-pipe too.
All 91-92 SD 305 TPI's are the same engine, different components attatched to it.
Old Jul 6, 2002 | 01:07 PM
avro206's Avatar
Car: 89 Formula
ah...I see. Still, the redlines should all be the same- if it was logical- which it isn't
Still the tech section must be wrong quoting a 4200rpm hp peak- should be 4400 then.
PurelyPMD
May 5, 2016 04:57 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
