wierd vin results
Old Jul 28, 2002 | 04:12 PM
Bluerocket's Avatar
wierd vin results
Ok I check out a fire bird for my friends brother and when we ran the vin I got this
Made in: United States
Manufacturer: General Motors
Make: Pontiac
Restraint System: Manual belts
Carline Series: Trans Am Special Edition
Body Type: 2 door coupe
4 is the CHECK DIGIT.
Model Year: 1982
Assembly Plant: Norwood
Production Sequence: 501613
what is a trans am specical edition and Why is there a fuel injected six in the engine compartment? i need to know if the car is worth saving it is in real bad shape then six is frozen the tranny is out the tranny cross member look like a turbo one from a 89
Old Jul 28, 2002 | 06:54 PM
Drew's Avatar
Just a long shot, but its probably an SE... basically a luxury base model. All T/A's are V8's except those damn bland 89 TTA's.
Old Jul 28, 2002 | 08:23 PM
92GTA's Avatar
Yup it's for sure and S/E. I owned an 82 myself. Nothing special but I can tell you it should not have a F.I. V6, it should just have a 2.8L 2-barrel carb:
LC1 (V6)
2.8L / 173 C.I.
8.5:1
102@4800 RPM
142@2400 RPM
2 Barrel Carburetor
Old Jul 28, 2002 | 08:39 PM
Bluerocket's Avatar
thanks the only thing going for it is that it had recaro seats
Old Jul 29, 2002 | 10:35 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
I hate to be blunt, but "Trans Am Special Edition" never existed in the third gen. it's one of those leftover myths that nobody ever got around to fixing on the VIN decoder. I assume your VIN 5th digit is an "X", and if it is, you have a Firebird S/E. S/E stands for Special Edition. Basically what an S/E is is a more luxurious model than the base 'Bird, with a V6 as standard equipment, whereas a base Bird had a 4-cylinder as standard equipment. Many interior luxury options were standard equipment on an S/E but they were optional, extra charge on base Bird and on Trans Am. You could get the 4cyl as credit delete or the LG4 V8 optionally. The standard suspension was level 2 which was a soft smooth ride better than the base Bird's. Optional was WS6 with a stiff racecar-like ride, just like on Trans Am, and added bigger sway bars, better springs, bigger wheels, positraction, and 4 wheel disc. There are more details but to sum it up, base bird was "economy", Trans Am was "performance", and S/E was "luxury". It was very much a GTA precursor, except far less popular than the GTA.
Your VIN should be 1G2AX8714CN501613.
One more thing: S/E's never got recaro seats. They got mandatory Viscount Bucket Seats with PMD logo on the backrest. That's the only option for 1982. If you have anything other than that, the seats have been swapped out.
Hope this helps
GT
Old Jul 30, 2002 | 09:07 AM
Bluerocket's Avatar
Ill check the rpo codes for the car becuase if it has the ws6 pagage I might save it from the junkheap.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
lanceflame44
Sep 25, 2015 12:28 PM
