Pull Down Hatch
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Pull Down Hatch
My friend in town has a slight problem, his hatch won't close because it's suposed to do this by itself.
It's an 87 IROC 350 TPI, less than 10 k miles, for sale for 10k......
Anyway he can't close the auto hatch because the rack is stripped out.
help!
Don
help!
Don
Car: 99 Formula
Axle/Gears: 342
take the housing off. Look down inside, there should be a lever that you push down, that will raise the hatch. MOst likely it's just stuck in the down position, this is usually the case.
Axle/Gears: 3.45, 3.27, 3.27
That switch is called the "striker sensing switch". Sometimes is does get stuck. Also check the 15 amp "LID" fuse, third from the left at the top row. I can e-mail you scans from my HELMS manual to diagnose the unit. I also have a 7-page repair manual I created that I can e-mail to you as well that will help you if needed. I stock the parts to repair these, should you require them. I also sell rebuilt units as well.
Lon Salgren
Top-Down Solutions
Lon Salgren
Top-Down Solutions
Lon,
Recieved your PDF catalog, thanks !
Your pricing is VERY competitive
I will forward the info and let you know soon what we need to do.
Don
Don
