Help on RPO codes
Old Sep 19, 2002 | 07:51 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
Help on RPO codes
I have located all the codes but these. I am buying this car Saturday and I would like to know what they are. This a 92 B4C
BOK between A31 and B2L
EGW ?
R6D ?
R8J ?
IPB ?
GTAFOX
Old Sep 20, 2002 | 03:52 AM
DeWynter's Avatar
I also need some RPO Codes
X06
Z31
R7F
R7K
IPB
any help would be nice
Old Sep 20, 2002 | 09:48 AM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
You guys are unlikely to get replies since there is a RPO decoder on this site, look around a bit this site has more than just these boards for info... https://www.thirdgen.org/cgi-bin/rpo/index
Old Sep 20, 2002 | 06:06 PM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
I have checked out the RPO codes on this site and about 4 others site. I even went to GM site. I have a pocket GM Production Options / Service Parts Operations hand book from GM Engineering Department,but know luck.
GTAFOX 1990 GTA 5-Speed
Old Sep 20, 2002 | 07:50 PM
DeWynter's Avatar
Thank for the help, also if the codes were in the PRO decoder I would have not bothered to ask
Here are my RPO Codes:
AN4 : RESTRAINT, PROVISION CHILD
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DE4 : SUNSHADE, REMOVEABLE HATCH ROOF
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D42 : SHADE, RR COMPT SECURITY
D5T : GEAR, SPEEDO DRIVEN
D81 : SPOILER, RR, AERO WING
D86 : PAINT, TWO-TONE, DELUXE
D9E : SENSOR, VEH SPD
D98 : STRIPE, ACCENT
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GM3 : AXLE REAR, 3.45 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
Unable to locate code IPB in our database!
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K05 : HEATER ENG, BLOCK-------------------/
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N10 : EXHAUST SYSTEM DUAL
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
PE0 : WHEEL, 16 X 8, ALUMINUM, LIGHT WEIGHT, STYLED
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
Unable to locate code R7F in our database!
Unable to locate code R7K in our database!
TR9 : LAMP, GROUP
UA1 : BATTERY, HEAVY DUTY
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UF6 : LAMP, INTR, CONSOLE, COURTESY
UQ1 : RADIO PROVISIONS, FOR STEREO
UT1 : TONE GENERATOR, WARNING
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
U19 : SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
U25 : LAMP, INTR, RR COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U62 : SPEAKER SYSTEM, DUAL COAXIAL
U75 : ANTENNA, POWER, RADIO
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WS6 : PERFORMANCE PACKAGE, SPECIAL
W66 : MERCHANDISED PKG, FORMULA
Unable to locate code X06 in our database!
Unable to locate code Z31 in our database!
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
12P : WHEEL COLOR PLATINUM
13L : SECONDARY COLOR, EXTERIOR, BRIGHT SILVER MET (91)
19Q : MOLDING COLOR (BLACK)
41U : PRIMARY COLOR, EXTERIOR, BLACK
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
78A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK RED (92}
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
82B : TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Old Sep 20, 2002 | 08:53 PM
Saywhut's Avatar
I've looked in several references for those codes, don't find any of them. Usually what those obscure codes tell the assemblers is like to use grey sunvisors instesd of black, or what color/pattern stripe, stuff like that.
The major ones are all in the decoders.
Old Sep 21, 2002 | 03:54 AM
DeWynter's Avatar
Thanks for the info I was wondering why they wouldn't be in any books
Old Sep 21, 2002 | 03:56 AM
DeWynter's Avatar
I was also wondering what the (91) or (92) on the end of the RPO code was?
Old Sep 21, 2002 | 05:33 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
DeWynter I found one code R7F " control, sales-Item no.31. Nothing on the others.
GTAFOX
Old Sep 22, 2002 | 04:03 AM
DeWynter's Avatar
Well thats one less to look for thanks alot, I also havent had much luck with any of the other codes either
Old Sep 22, 2002 | 10:36 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Well you guys at least know your RPO codes. My car has been repainted and the label on the inside of the door that has the RPO codes is gone. So I have no idea what my car is configured with. Other than the obvious. It does say Performance Suspension on the dash which indicates WS6. But that's the most I can tell you.
Old Sep 22, 2002 | 01:23 PM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
RPO CODES
Go to your GM parts department and as them"PLEASE" run your vin # for a print out of RPO codes. That is what I did with the 1990 GTA to check on what I was buying.
GTAFOX 1990 GTA 5-speed
Old Sep 22, 2002 | 02:02 PM
87WS6's Avatar
Thanks man. That will help alot. I was wondering if there was any way to find that stuff out. :hail:
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
