Removing the backseats
Old Oct 26, 2002 | 05:34 PM
91-Z-Speed's Avatar
I was just wondering how to remove the bucket section of the back seats, because I can't find a good unbolting place.
Old Oct 26, 2002 | 05:51 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
the bottom of the rear seat is removed by undoing the 1/2in bolt dirctly in the fron middle bottom (you'll see it then you just pull and it will come , sometimes they're vecroed to the carpet. The upper part, in each side far left and right underneath you'll see a bracket w/ anoher 1/2in bolt undo that and if its split seat, slide it off the rod in the middle, one seat just pull up.
Old Oct 26, 2002 | 06:59 PM
91-Z-Speed's Avatar
thanks a lot, that little bolts a little hard to get to with a ratchet :P
Old Oct 27, 2002 | 06:48 AM
Z28DJP1987's Avatar
The fasteners to remorve the rear seats are 14mm and not 1/2" for your info.
Old Oct 27, 2002 | 07:37 AM
91-Z-Speed's Avatar
1/2 worked, and the bolt doesnt look stripped at all, but ill checka 14 mm on it
Old Oct 28, 2002 | 04:37 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
originslly posted by 91-Z-Speed
That's why they make extensions!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
