difference between B2L and L98
Old Mar 6, 2003 | 09:53 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
what is the difference between these two engines? arent they both 350tpi, why two codes?
Old Mar 6, 2003 | 10:57 AM
87350IROC's Avatar
Car: 87' IROC
L98 is the engine code for the 350TPI. B2L is the L98 engine package. This package in 1987 at least, included 4 wheel discs, oil cooler, BW 9 bolt, 3.27 ratio, ect... They were opions that went along with the 5.7L engine.
JP
Old Mar 6, 2003 | 01:17 PM
Drew's Avatar
I haven't heard this one in a while.
Basically L98 is the engine code.
B2L is listed in addition for various reasons. Whether it identified options that were standard with the L98, or whether it denoted the L98 installed in the Fbody platform, is anyones guess. It makes about as much sense as MX0 and MD8 both indicate a 4 speed auto tranny.
Old Mar 7, 2003 | 12:15 AM
MdFormula350's Avatar
the rpo code doesnt say much.
https://www.thirdgen.org/cgi-bin/rpo/index
L98 : 5.7 LITER V8 TPI ENGINE
B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
Old Mar 7, 2003 | 10:58 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
JP
i think youre right, my 89 is B2L L98 and it has all thats listed, but its got a cheesy 2.77 ratio.
Old Mar 7, 2003 | 11:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The package details varied from year to year.
But the explanation is correct, that L98 is the engine, and B2L is the package that installed it in a car.
Old Mar 7, 2003 | 11:41 AM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Doesn't it have something to do with engine makeup? One being for the Camaro's B2L/L98-iron heads&exhaust manifolds,and different internals) whereas the corvette L98 has aluminum heads & exh manifolds plus different internals?
Old Mar 7, 2003 | 02:00 PM
Abubaca's Avatar
It's the same thing as Extra Value meals. When you order a #1 you get a Big Mac, fries and a drink.
When you order a B2L, you get an L98, the "fries" and the "drink". NOT just the L98.
Old Mar 7, 2003 | 09:08 PM
David M's Avatar
Car: '84 Z28
Engine: L69
But I bet your car has a high side of 150mph+!!!
The 2.73 and 2.77 rear gears are great for hurtling down the interstate.
Old Mar 7, 2003 | 09:55 PM
jms's Avatar
jms
The L98 appeared first appeared in the 1985 Corvette.
With IRON heads.
The aluminum heads didn't come until mid-way through the 1986 model year and if I remember correctly only on convertibles. Or vice-versa. The point is all the 'Vettes didn't get the aluminum heads the first year they were used.
Supposedly, the 1987 model year 'Vettes all got aluminum heads.
B2L is the package for the L98 engine in the f-body.
I don't recall any other Chevy smallblock engine code beginning with anything other than an 'L' or a 'Z'.
For those that argue the IRON head 350 TPI engine should not be an L98, remember, the f-body L98 is closer to it's "roots".
So, technically, the ALUMINUM headed 350 TPIs should have been called something OTHER than L98.
After all, in the 1960s, the 375 horse 396 was called an L78 but when optioned with the aluminum heads, it became the L89.
jms
Old Mar 8, 2003 | 07:56 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Its GM's way of adding confusion. Just remenber a F-Body and Corvette L98 are the same basic layout but packaged different for each car.
Old Mar 8, 2003 | 11:21 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
hehe couple that with my nice .5 sixth gear ratio, and i bet i could go in excess of even that. not about to try it though.
Old Mar 9, 2003 | 12:33 AM
Abubaca's Avatar
I've been to 130 with my 2.77 and I wimped out, but she had more to go. I've seen tests show 154, and heard stories about 160.
But I've heard stories about boogie men too.
Old Sep 12, 2012 | 08:53 PM
CradleofFilth08's Avatar
Car: 1992 Camaro Z28
Transmission: 86' 700R4
Axle/Gears: 10 Bolt, 3.42's
Re: difference between B2L and L98
Old thread, buuuuuut.....153 and I backed down with more to go because I felt like I was about to lift off.
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
greenyone
Sep 2, 2015 03:39 PM
