[1987]: Difference between Firebird and TransAm models?
Old Mar 21, 2003 | 03:31 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Posting this for my brother who I guess is looking at a '87 Firebird. Just wondering what the differences were for that year. Thanks!
p.s.
It supposedly has an engine from a '87 vette in it. He's going to look for the engine stamp to confirm it.
Old Mar 21, 2003 | 05:03 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
In 1987 --
Trans Am's had ground effects, fender vents, and vents on the hood. They only had V8 engines
Firebirds had no ground effects, vents and a plain hood. They could have V6 or V8 power. the V8 would be carbuerated.
That is an extremely general list of what to look for. I'm sure others can add to it
Old Mar 21, 2003 | 06:48 PM
scorp508's Avatar
Car: Corvettes
Thanks for the start! The "base" list of included components is what I'm looking for, not the others you could add.
Old Mar 21, 2003 | 07:42 PM
Redbird350's Avatar
Car: 89 Formula 350
Engine: L98 350
Transmission: T-5 Manual
I do belive that in 87 the TPI was available at least in the 305. I also think the 350. If I am correct 87 was the first year the Formula was brought back and in a Formula350 you would of course find the L98 TPI 350. This engine was used in the Vette previously but is de-tuned for the firebird and camaro. The cosmetics described in the post above are correct.
Old Mar 23, 2003 | 12:47 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
In 1987 was the first year of the Forumla Firebird which could be had in a 305 and a 350 TPI. If it's a plain Firebird it would only be available in the carbed V8. Formula's could be TBI, TPI or carb. Except the 350 which was TPI only. No Firebird's came with GFX. Any option that a Trans-AM could have the Firebird Formula could have except the GTA and ground effects packages. Hope this helps.
Old Mar 23, 2003 | 07:55 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
What 87WS6 said, except there was no TBI in 87. You also couldn't get the WS6 suspenion or rear disc brakes in a base Firebird.
Old Feb 14, 2024 | 07:54 PM
Gauley71's Avatar
Re: [1987]: Difference between Firebird and TransAm models?
I had an 87 Pontiac Trans Am. It was fire engine red with silver ground effects, red spoiler, and t-tops. It was bad ***. I was 19. The 1987s were. like this
FireBird... 2.8 v6,
Trans Am 5.0 v8 (spoiler, grd.eff.,ttops. options)
GTA 5.7 v8 (spoiler and grd eff options)
the tops weren't an option on the GTA due to the fact that the frame could twist with the 5.7. Hope this helps some.
Old Feb 14, 2024 | 08:54 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
SMH...
evilstuie
Jan 9, 2020 08:29 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
jahblah
Aug 12, 2015 05:54 PM
MENINBLK
Aug 5, 2015 11:58 PM
