How many 82 Z's had rear discs?
Old Apr 21, 2003 | 10:42 AM
Mad-Mic's Avatar
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
how many 82 Z/28's had factory rear disc brakes? i could of sworn i read only about 600 cause of a late change order and the maker of the calipers couldn't produce them in large quantities.
can anyone collaborate on this? BTW my car has a factory rear wiper also and i've never seen this before on any Camaro or Transam.
Old Apr 21, 2003 | 11:50 AM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Front & Rear Brakes for the 82 were J65 & 6,254 were made
As for the Rear wiper was C25 14,031 were made
The Rare part of the Disc brakes were the Pace car only 25% of them came with the combo CFI & Rear Disc
Old Apr 21, 2003 | 03:59 PM
Mad-Mic's Avatar
thanks cowgirl
where do you find the RPO codes in the 3rd gens?
Old Apr 21, 2003 | 04:45 PM
I got it from the Camaro white book
you can find it at most Book stores Or most auto specitaly stores.
Old Apr 21, 2003 | 04:46 PM
Originally posted by Mad-Mic
thanks cowgirl
If you have a 82-84 most of the cars dont have them.
You have to locate your Build sheet.
Old Apr 21, 2003 | 05:06 PM
Mad-Mic's Avatar
thanks for your help cowgirl
any idea where it might be? on the car that is? i never seen it and had this car on lifts many times.
Old Apr 21, 2003 | 05:11 PM
It could be in a number of places, Normally its under the gastank. (its a lose piece of paper) it could also be under the seats, under the carpet, behind any of the paneling. Could be anywhere in the car
Old Apr 21, 2003 | 05:16 PM
Dirty Rob's Avatar
Ebays a good place if the other ones dont work out for you.
Old Apr 21, 2003 | 09:56 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I have found the buildsheet to 2 82 Indy cars under the passenger seat springs. Reach under and see if you can feel paper in the springs. If so, the best way to remove it is to remove the seat first. Otherwise, you will have nothing but ripped paper!
Old Apr 21, 2003 | 10:00 PM
Mad-Mic's Avatar
sounds good everyone i'll have to take a look! i'm currently slowly working on the engine the short block is done. will an L98 block bolt to the CFI intake? if not it's going in the vette or should i say L98 heads. i know this car had 1.88 intakes .... Yick
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
