what speedo?
Old Apr 13, 2003 | 11:55 PM
firebird89355's Avatar
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
what speedo?
my car originally came with a l03 305 and i was wandering if the car is a T/A or a FIREBIRD the reason im asking is because it has the 140 mph speedo in it did the firebird's come out with the140 speedo or was it only optioned in a T/A? thanx thomas
Old Apr 13, 2003 | 11:57 PM
oh yeah
i have yet to find my rpo codes either.
Old Apr 14, 2003 | 10:35 AM
MdFormula350's Avatar
hmm my formula 350's had 140 speedo's
your rpo codes should be either under the console lid or in the rear trunk storage compartment.
Old Apr 17, 2003 | 06:24 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I equate the 350 with the 140 speedo, but not the 305....hmmmmm
Bill
Old Apr 17, 2003 | 07:42 AM
amandagregory's Avatar
only lb9 305's with the 3.23 rear and all 350's got the 140 speedo. lb9 w/2.73 rear got the 120 mph speedo. all other 305 (lg4 etc) came with 85 mph up to 1987 then 120 mph 1988-1992.
Old Apr 18, 2003 | 11:37 AM
Drew's Avatar
It all depends on your RPO's.
My V6 Firebird has a 140mph speedo, it doesn't mean anything, I swapped it in. Its got a performance suspension badge on the dash, 36mm front sway bar, a 'Z' high effort steering gear, leather seats, an overhead console, auxilary interior lighting, etc etc etc... It doesn't matter, cause its all stuff I did. These are used cars. If you're going to try to find out exactly what you're dealing with, check your RPO's. If you don't have you RPO's then you're going to have to do a lot of research.
This thread is chalk full of misinformation, the bottom line is that the 140mph speedometer was standard anytime a car was equipped with an non-standard engine. Chances are someone swapped the stock speedometer for the 140mph speedometer.
Old Apr 18, 2003 | 03:09 PM
Bill Speed's Avatar
Engine: L98 350 TPI
OK, since a swap is relatively easy for this item, you can check if you have dual cat exhaust! I do, so I would say "factory" 350 and Formula options on the performance end. That's true of my car anyway.
I do see the guages offered for sale, and that argument makes sense
Bill
Old Apr 19, 2003 | 03:29 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I cant make any sense out of this. Why didnt the 2.73 come with a 240mph because with that rear axel you should be able to go faster than a 3.23 rear axel. So it should be the other way around or anyway thats what i think.
Old Apr 20, 2003 | 10:11 AM
PontiacV8's Avatar
Car: F-Body / Cadillac STS
Engine: 305 TPI LB9
Transmission: TH 700 R 4
@amandagregory
...hmmm....I don´t think so....
LB 9 305 w/ 2.73 rear and 220+ "kph"-Speedo (approx. 140 "mph") ; RPO U18; UB3; GU2; G80; JG1; J42; LB9; MD8; MXO; WS6...
Old Apr 20, 2003 | 01:30 PM
Drew's Avatar
What's the point of this thread? Do you want to know if your car is a Firebird or a Trans Am? If that is what you want to know, then it would be helpful to know more facts about your car. If you want to know what speedometer you should have, again more details would be helpful.
Like, what year is your car, what is the VIN number, do you have the RPO codes, etc?
Technically the 140mph speedometer was never available in a base model Firebird, only the Trans Am, Formula, and GTA, and only then with the upgraded engine in most cases.
Which hood does your car have?
Which wheels?
Any badging? GTA? Trans AM? Formula?
Old Apr 22, 2003 | 09:10 AM
Bill Speed's Avatar
Engine: L98 350 TPI
240 MPH!!! Yeah, now your talking!
hehe
Seriously ...that's KPHright?
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
