manual trans
Old Apr 24, 2003 | 05:56 PM
brandonff's Avatar
manual trans
3rd gen firebird
6cyl
5spd manual
.......if i do the 305 engine swap will the 5 spd fit?
thanx
~Brandon
Old Apr 25, 2003 | 05:13 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Yes, but you'll need a V-8 bellhousing.
Old Apr 25, 2003 | 06:41 PM
brandonff's Avatar
thanks, how much does the housing run? can i pik one up from a salvage yard?
Old Apr 25, 2003 | 07:45 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
i thought that the trans wouldnt bolt up, thats what i was told when i was lookng into putting a 350 in a camaro i had with a 5 spd, u need to post this on the trans/drivetran board or the motor swap boad, or both of them, why are u swapping a 305 in, the power increase isnt very much, id figure there about 160hp and your v6 is 125 hp, if i was u id go for a 30, there a dime a dozen at salvage yards, but to answer the bellhousing question, i can get one around here at a salvage yard for about $5
Old Apr 25, 2003 | 11:54 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It depends on the 305. The TPI version has alot more torque and HP than the V-6. The factory TPI 350 doesn't have that much over the 305. But any TPI engine has alot over the V6.
Personally though if you are going to do an engine swap you should get all the cubes you can afford. You'll be glad you did later.
From everything I have heard though the T-5 5Spd doesn't hold up to alot of power. So if your looking to make alot of power you should ditch that as well. Don't forget you'll need alot of things out of a V-8 car to do the swap. You'll need the motor mounts front springs and so fourth.
Old Apr 26, 2003 | 10:14 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
No one mentioned the V6 T-5 is different then the V8. Different geat ratios and not nearly as strong.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
