To fix or not to fix
you can see the hood "wings" and if you look close the passenger door has a bad scratch, but other than that its clean. What would that car be worth if the body was fixed and the engine was still running good after 190000 miles?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I would fix it... if the parts car is the same color, the repairs (body anyway) are bolt ons. One afternoon and the car could look 10 years younger
Originally posted by kerryismygirl89
It already looks better than a lot of Third Gens you see floating around.
Not sure about the door though.. never did one.
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
absolutely, no question about it. fix fix fix fix, that is 2 stout blokes, and 1 afternoon's work.
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
the bodys in good condition but that engine has alot of miles on it. I say loose it if you don't plan on doing anything with the engine soon..
LO3 is TBi isnt it? provided tis been looked after, it should be good for 300 000 miles
Car: 1989 Firebird
Engine: 5.7 LS1
Fix it, and if the engine goes well you can do a good rebuild for 1k thats less than the paint will cost.
If not sell me the center brakelight housing, LOL I can't find one in good shape, mine is missing one of the side extensions, anyone have one PM me.
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Originally posted by fast83camaro
Ditch the Hitch....if you are not using it.....
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Absolutely. Fix it. From those pics, it already looks better than a lot of Third Gens you see floating around.
dont let a stupid place fix it for you and make a mess of it, overspray, cheap paint, dirt in paint, etc.
be casreful, watch them closely !
while oyure at it i would underbody coat the underside of the car espcially under rockers and floor pans! try to get it up on a four point twin shop lift if at all possible.
good luck
