What year ?
Old Jul 29, 2003 | 02:39 AM
Lateral G's's Avatar
What year ?
what years where turbo 350 trans used?
what is first gear ratio of the 350 if it was used?
what years had the best heads?
what years and motors had the best cam? (highest rpm & HP)
what years had the best suspension for cornering?
what is the best way to get 60 MPH in first gear using all stock parts ???
thanks!!!!
Old Jul 29, 2003 | 05:10 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Too many "What year" questions??????
Old Jul 29, 2003 | 06:20 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Re: What year ?
thanks!!!!
1. None.
2. Not used.
3. 87-92 350 TPI's.
4. 87-92 350 TPI's and 305 5-Speed G92 cars.
5. 85-90 IROC-Z28's.
6. -------------------
Old Jul 29, 2003 | 07:16 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
2.52 th350 first gear
1.52 second direct 1 to 1 in third
B&M makes bracket you need to connect torque arm to the tranny, its simple and easy to install no fabrication needed at all, just three tailshaft bolts to remove and reinstall, and the bolts for torque arm bar mount cushions and shell.
simple, i just swapped to th350 from thm200C it out in my driveway the other day
avoid alot of the 882 heads and the 624 heads too, both light crack prone castings, both are 350 and 400 heads, not 305 or 307 or 327 heads. 882 started in 74 and its the 74 ones that tend to be the cracking one, and the 624 were about 79 and up all through 80s common and junk.
Old Jul 29, 2003 | 11:51 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Also the 85 305 TPI came with the vette cam.
Old Jul 29, 2003 | 01:32 PM
sorry about all the 'what years'.... anybody know specs. on the good cams... lift ,duration, lob to lob angles???
and if all those other heads are weak which ones are the good ones???
Old Jul 29, 2003 | 01:42 PM
DJP87Z28's Avatar
It will save you some time, just look up the Tech Data on the Home page of this site. Thats were most of the info is coming from.
Old Jul 30, 2003 | 01:28 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The L69 (305 HO 4bbl) had the best heads of all the 305s. They were 58cc chambers with 1.84 intake / 1.5 exhaust valves. On that engine, it made 9.5:1 compression.
The casting number was 416 i beleive.
Old Jul 30, 2003 | 11:10 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Those are the same heads as some of the LG4's used. My 82 LU5 has the 416's, just like my 83 LG4 TA I use dto have. Sme casting number, valve size and everything.
colton_carlson
Mar 8, 2019 12:21 PM
Cornholio7979
Sep 20, 2018 02:31 AM
92GTA
Apr 9, 2016 07:39 AM
Americanmouse
Sep 7, 2015 12:10 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
