L69 drive trains
Old Aug 21, 2003 | 12:17 AM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
L69 drive trains
As i understand it theL69 in 1984 came in either the 5 speed 3:73 or an automatic with 3:42 cogs.My friend has a 84 z with an L69 and the gt4 option.Is ths an od combination?
Old Aug 22, 2003 | 10:56 AM
82RECAROTA's Avatar
Old Aug 23, 2003 | 08:47 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i have it, a4 3:73's, first gear revs hard with that combo
Old Aug 24, 2003 | 11:12 AM
David M's Avatar
Car: '84 Z28
Engine: L69
I thought ALL L69 F-cars came with the 3.73 rear gear. I've never seen one with a 3.42 gear.
Old Aug 24, 2003 | 06:21 PM
82RECAROTA's Avatar
Old Aug 31, 2003 | 05:21 PM
Tongi's Avatar
Car: '84 Trans Am Recaro Edition
Engine: L69 305 H.O.
Transmission: 700-R4
i guess '84 recaro's had 3.73.
Old Sep 11, 2003 | 02:07 AM
Ron84TA's Avatar
how can you tell
How can you tell which rear you have ?
Old Sep 11, 2003 | 06:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take off the cover and look, while you're changing the fluid (as you should be doing occasionally anyway). Screw all the turns counting and speedo/tach stuff and "codes", none of it is accurate or dependable. Bypass all that and move directly to reality.
Don't forget to put posi additive in it if you see that it has that.
Old Sep 11, 2003 | 07:43 PM
Ron84TA's Avatar
I have it its on the dealer invoice 84 ta automatic
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
