Found NEW Gm rear hatch struts - cheap
Old Dec 15, 2003 | 12:05 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
http://cgi.ebay.com/ebaymotors/ws/eB...category=33647
Old Dec 15, 2003 | 12:29 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Good price, but they're for a non-defrost, non aerowing car.
Pete
Old Dec 15, 2003 | 12:46 AM
scottmoyer's Avatar
I did notice that and forgot to mention it. What does the aerowing have to do with the struts? Is it that they aren't the heavy duty shocks for the added weight? I need the heavy duty for my rear louvers.
Old Dec 15, 2003 | 01:07 AM
That's right, the aerowing ones are heavier-duty to support the additional weight.
AFAIK, there were three different options: 1)plain struts like these; 2)defroster-equipped; and 3)defroster with wiper/aerowing.
Old Feb 3, 2004 | 01:22 PM
MHarris's Avatar
Car: '92 Firebird w/T-Tops Black w/Tan Interior
Engine: 305 TBI
Transmission: 5 Speed
Kragen...39.95 per side. Lifetime warranty. 15 minute install. Turn the key and don't lift a finger. No bull***t. If they stop working take 'em back put new ones on. No questions asked. You're out like 30 minutes for install plus driving.
Old Feb 3, 2004 | 01:39 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
I heard there are 3 part numbers depending on weight loads. I too need a strong one for my, dare I say it, LOUVERS !
Old Feb 3, 2004 | 03:25 PM
MHarris's Avatar
Engine: 305 TBI
Aww Maaaan. Louvers are so 80's! LoL
It's all about Sweet, Smooth, Tinted, Straight Black Glass!
Old Feb 3, 2004 | 10:29 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
Stuck in the 80's
i like the louvers, need we all forget our cars are from the 80's
but then agagin some may take a classic 67 chevell and lower it and put some strange wing on it and some other outaplace mods just because we're in the year 2004. Bah...
keep what ya like i am putting my louvers back on when i am done painting the car.
Jeffw
Old Feb 4, 2004 | 11:28 AM
cdartz's Avatar
Re: Stuck in the 80's
I'm with you. There is nothing wrong with an 80's car looking 80's. I actually prefer to keep my cars looking mostly stock. The guy who spends lots of money to update his car will only be disappointed in 5 years when all his expensive mods are out of style. At least your louvers look period correct and will always be acceptable in that way.
Old Feb 4, 2004 | 03:00 PM
Mr. TurboTA's Avatar
Those and the front hood struts are the only non-GM parts that I use on my car (uh, and Flowmaster! HeHe!)!
I have spent lots of $$$ on the GM replacements (yes, the right ones)! They don't last longer than a few months! And that's here in So-Cal!
I too, when the AutoZone/Pep Boys route! And I have never had to go back (knock on wood!)! And they are lifetime warranty!
Good luck to those of you going the GM route!
My take,
George
Old Feb 4, 2004 | 03:03 PM
MHarris's Avatar
Engine: 305 TBI
Touche!
But I drive a '92 so am I exempt? Or do I need to hang some parachute pants from my rear view mirror?
Old Feb 4, 2004 | 04:40 PM
88txiroc's Avatar
My take,
George
If you have a fiberglass hood, you really dont have a choice but to get GM parts. All the others will be too strong for the hood. GM sells them for the 82-83 Camaro with the glass hood, and they cost some big $! About 45 per side, IIRC. If someone knows of a cheaper one that is not too strong for glass, let me know.
Old Feb 4, 2004 | 04:58 PM
MHarris's Avatar
Engine: 305 TBI
Why does it matter if you have a fiberglass hood or not?
How can they be "too" strong?
Old Feb 4, 2004 | 05:59 PM
88txiroc's Avatar
If you have the regular supports, when you go to close the hood, it will crack right in front of where the hinges bolt to the hood. The glass hoods are not as strong as the steel ones, nor do they have as much underside bracing.
Old Feb 5, 2004 | 10:02 AM
MHarris's Avatar
Engine: 305 TBI
Re: Hood Stick
Has anyone heard of, seen or succesfully installed a hood stick (like 90% of the rest of the cars in the history of automotive engineering have) in a Firebird or Trans-Am?
Old Feb 5, 2004 | 11:24 PM
bes217's Avatar
why would you want a stick? It just gets in the way when you are trying to work on your car.
Old Feb 6, 2004 | 12:47 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
sticks are for beating people, now a prop rod on the other hand
Old Feb 6, 2004 | 11:14 AM
MHarris's Avatar
Engine: 305 TBI
I'm not pulling the motor so I'm not really worried about a 1/4 inch wide stick in my way.
Anyways it's really windy where I live and the stick makes me uncomfortable. I used to lock a set of vice grips on the shaft of the hood strut (after the strut stopped working) but it started to chew up the shaft.
I know I can just buy new ones but one day they are going to give out and I don't wanna be under the hood when they decide to. A hood prop is a good backup.
I was just wondering if anyone has seen one or has one successfully installed?
Old Feb 6, 2004 | 11:20 AM
MHarris's Avatar
Engine: 305 TBI
My prop rod doubles as a beating stick.
Old Feb 6, 2004 | 08:34 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
I got a prop rod on my 84 z w/ a fiberglass hood. It looks factory. The preveious owner installed it i dont have a pic as of now though
Old Feb 9, 2004 | 11:14 AM
MHarris's Avatar
Engine: 305 TBI
How does it lay in the engine compartment?
Does it lay parallel to the fender or the front bumper?
Did they install one of the clips for it to sit in when it lays down?
Is it the right length to hold the hood up fully extended?
Old Feb 9, 2004 | 04:22 PM
I have a prop rod for the hood of my Formula; it came on a Firebird parts car I got a few years ago. I have no idea what type of vehicle it originally came off of though.
Here's the only pic of it I could find for now. Taken while the Formula was under construction - there's no fender on it in the shot. I might try to get some better ones tomorrow.
Old Feb 9, 2004 | 07:01 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Why couldn't you use somebody's worn out ones from a steel hood? I would imagine they would be strong enough to hold up a glass hood.
I know when I went from the original spoiler on the hatch to the fiberglass ones, my original struts would work again because of the lighter weight.
Old Feb 9, 2004 | 10:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
As to the original content of the post... there seemed to be a few different hatch struts for the 'birds... http://www.deadbird.org/pnfire/c13.htm
MightlyLift struts from Autozone (and other places) are cheap ($25ish/each) and usually carry a good to lifetime warrenty as well.
Old Feb 13, 2004 | 03:40 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
:-( i wasnt even born till 85 what are those?
~hijacks thread~
Old Feb 14, 2004 | 11:23 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I just picked up a set of strongarm struts for my T/A.... they have two part numbers they carry at advance (schuck's, kragen, for you northern f*ckers...) (j/k) one for bare (no spoiler or anything) and one for fully loaded.... wiper, defroster, and spoiler. I got the heavy duty ones, because I have a spoiler, and want to install a defroster. as for the hood struts, I haven't found a hood i liked yet, except the turbo vette style hoods, and the 'bird hoods that have those four vent panels in them. anybody know where to get one of those turbo vette style hoods? I can't find them anywhere.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
