Help identifying 4-speed manual trans
Old Jan 22, 2004 | 11:52 AM
DSM's Avatar
DSM
Car: 84 Z28
Axle/Gears: 3.73 Torsen
I acquired a transmission when I bought my 84 Camaro and I'm trying to identify it. Its a cast iron case 4 speed, external linkage, and it has what looks to be a torque arm mount. The numbers on the trans are 14030974 and 6261888. Is this an 82 F-body 4 speed or something else?
Old Jan 22, 2004 | 12:49 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
If the tranny came in an F-body (and do you know if it did?) it has to be from an 82 or maybe early 83. That's the only year(s) of 4 speeds. But as you said, maybe it's not originally from an F-body
If the side plate has 9 bolts and looks like a "lying down" letter D, it's a Borg Warner T-10 like mine. That's the good one. It's also an aluminum case.
Otherwise, it could be a Saginaw, which was also available in 82.
I assume they all would have a torque arm mount? Not sure of the numbers either.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
