4L60 and 700R4
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
4L60 and 700R4
are the 700R4 and the 4L60 the same transmission if not whats the difference, and what year did they start using the 4L60? I have a 1990 GTA is it 4L60 or 700R4?
Car: 1987 Z28 Convertible
Transmission: 5-speed
They are the same.
Internally, they are. The difference is the 4L60 is electronically controlled, the 700R4 is not. And because our ECM does not control transmission function in any third gen year, only the 700R4 was used.
[B]GM changed the name around 90 or 91.[b]
If this is true, the 4L60 was not used in the third gen F-body.
So the general answer is no 4L60's were used in third gen F-bodies. They were all 700R4's.
Car: 1991 Z28
Transmission: 4L60 automatic
'90 was the year they changed the name or at least that's what it says in my Chilton's manual and yeah 4thgens had 4L60E.
Originally posted by Willie
[B]They are the same.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by vicV8rs91
speedo is driven differently isn't it?
So there is no real difference to the transmissions but their names and they started calling it 4L60 in 1990 instead of 700R4.
Engine: 383 Carb
Transmission: 4L60
try swapping them
try swapping them
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
