AC Delete on 82-87 Cars?
Old Mar 31, 2004 | 01:47 AM
stiers's Avatar
I want to remove the AC on my 87 GTA and I noticed that it is just one belt going to it not the serpentine setup my other car has. Can I just take that line out and unbolt the compressor and bracket? I want this to look like it was from the factory...how did they do the AC deletes in these cars?
Old Mar 31, 2004 | 12:35 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I put A/C into my 82 LG4.
IIRC, I had a single pulley power steering pump that just ran off the crank.
When I put in A/C, I had to get a dual pulley for the power steering pump as the belt ran from the A/C compressor to the steering pump and crank.
So that would mean that you could just remove that A/C belt and make sure the second belt that goes to the crank is nice and tight.
Come to think of it, I don't have the A/C compressor in right now so that's exactly what I'm doing myself.
Not sure if all the other years are the same for belt setup.
Old Apr 2, 2004 | 02:28 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I even have a set of original block-off plates for the vents that came out of a non-A/C 84 'Bird...pretty hard to find.
Old Apr 2, 2004 | 11:44 PM
cdartz's Avatar
Why do you want to remove it?
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
drathaar907
Aug 6, 2015 04:20 PM
