Could you get a 3.45 gear in a 87 or 88 Trans Am with a 5 speed 305TPI?
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
In all the documentation I read, (gm brochures, tech sheets, etc), it appears that if you ordered "just" a Trans Am, you only got a 3.08 rear gear with a 305 5 speed.
If you ordered a GTA or Forumla, then you got the 3.45 rear gear.
I found some conflicting info that if you ordered the MK6 5 speed, then you got the better rear gears ... although the MK6 was not really a known option, at least not on the order sheets.
Mark.
Mark.
Axle/Gears: 9-bolt/3.45
The 3.45 in my Formula was part of the W66 Formula Option package, and I'd guess it's also part of a GTA Option package. So that should help confirm your findings on those models.
But I think TAs could be purchased with or without all the performance upgrades. So if someone wanted the 3.45, it probably got ordered individually as G92 Performance Ratio.
1992 Trans Am
Aug 8, 2015 08:16 PM
