really quick auto to manual engine
Old Dec 18, 2004 | 02:41 PM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
i have a vin G that was an automatic that im going to put in a camaro that was a vin G T5. i was reading the article on how to do an automatic to t5 swap... and in it, i saw that it requires a pilot bushing. whats the difference btwn the pilot bushing and pilot bearing? do i need both? i know the bearing goes on the block but wheres the bushing go?
Old Dec 18, 2004 | 03:02 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
A pilot bushing is a peice of machined "Oil-lite" brass. Its cheap to make, doesn't cost much, and doesn't last as long as a bearing. Most OEM clutch kits come with these to keep the cost down.
I always throw them out and use bearings.
A pilot bearing is a bearing with ***** or rollers. They cost a little more but will last a long time and create less drag and wear. This equals a little smoother shifting too. The factory usually installs a pilot bearing rather than a pilot bushing.
The pilot bearing/bushing goes into the end of the crankshaft to support the input shaft of the transmission.
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
