floorboard problem
Old May 8, 2005 | 08:45 PM
Blkdth87's Avatar
Car: 1989 TRANS AM
Engine: 2004 GTO LS1
Axle/Gears: 02 ws6 torsen diff 3:42
floorboard problem
heres my situation.
i pulled my interior out,
found rust from the back of the front seats up to the front of the rear seat bracket. on both sides.
rear front d/s seat bracket is starting to rust.
p/s front floor well area where it dips down is starting to rust, has like a quater size hole, but wont know for sure until i start grinding.
d/s front floor looks clean.
i have stress cracks on the trans tunnel???
i noticed one in the front by the fire wall,
noticed 3 more by the shifter.
and one about 3 inches long alittle further back
should i weld the stress cracks, and patch the panels with junk yard pieces?
should i put a set of new pans in?
or should i just find another body?
Old May 8, 2005 | 09:56 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
It all depends on what you want to do with the car. Is it an investment, a daily driver, or do you plan to keep the car forever.
Old May 25, 2005 | 04:03 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I have the same situation. My car is ate up with it. I haven't pulled the carpet, but a look underneath will make your heart sink. I even found a rust hole in part of the front frame.
I thought about the amount of work it would all take. That is considering to that my quarter are rusting out in the dog leg, and there is rust all around the t-tops and windshield. With the cost of repair for mine, I can buy one in a lot better shape. I'm throwing all my $$ at the drive train because I can transplant it later. Hopefully dropping in my vortec 355 in a couple of weeks
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
