Rare Irocz ?
Old Sep 18, 2005 | 11:29 PM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
Rare Irocz ?
I have an 88 IROC with some rather interesting parts. The guy I bought it from had no idea what is was other than it was a camaro, he had gotten it from a friend who owned a chevy dealer. The car is a 305tpi 5 speed. It came with global west everything and every bushing that could be replaced with a solid bushing was and everything else is polyurethane. It only has the stock torque arm all else is replaced. It has 16" gta type wheels on it. From the papers it came with it had a crane cam installed in it. Also a edlebrock base manifold, tpis runner, air foil, adj. fpr, edlebrock coated headers with 3" flowmaster exhaust. The clutch is stiff as hell and has a hurst shifter. Now the odd parts it has an oil cooler that uses coolent. There is a sandwich adapter between the oil filer and block and has hard lines running to the cooling system, it looks very stock and I haven't seen a coolent oil cooler setup that isn't factory. It also wears 1le brakes, with matching stainless steel lines. The car is almost perfect with under 75K miles. Is it a 1le car? Is the coolent oil cooler a ultra rare item? Is the car itself ultra rare? With all these parts could it have been used by GM to promote the IROC 1le cars? I have a ton of pictures I will send to someones email. I am retarded and can't post pics
Old Sep 19, 2005 | 03:01 AM
ajmclean's Avatar
if u could post the rpo codes i can tell u if its 1le or not
Old Sep 19, 2005 | 07:43 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
GM never promoted the 1LE cars...
John
Old Sep 19, 2005 | 06:16 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
It sounds like a car with alot of aftermarket changes made. This car is far from a factory car at this point. Why would you think it's rare?
Old Sep 19, 2005 | 09:30 PM
Car: 88 IROC
Engine: 305 tpi
I figured that it might be an actual 1le car, the weird oil cooler setup ect... It has a really big driveshaft as well. It is not aluminum but compared to my buddies 89 formula it is huge. The rpo codes are in the glove box right. It just sounded like a factory 1le. The brakes, oil cooler, and I heard that some came with the gta type wheels. Do you need the vin as well?
Old Sep 20, 2005 | 01:43 AM
scottmoyer's Avatar
The fact that it has the 1LE brake setup and all,I would say that some past owner modified that part of the car also. At this point, almost anything can be done. Not a factory setup anymore. You have 1 modified car!
Old Sep 20, 2005 | 03:26 AM
ajmclean's Avatar
ya u wil find the rpos and the vin in the glove box betweenthe 2 seats
Old Sep 27, 2005 | 09:18 AM
Car: 88 IROC
Engine: 305 tpi
Sorry it took so long to reply this semester is killing me!!
Ok this from the top down
1G1FP21F1JL179758 1FP87
AC3 AG9 AR9 AU3 A01 A31 A90 B18 B3W B34 B35 B4A
B84 CD4 C49 C60 C95 D67 D34 D42 D7J D80 D88 E5Z
E9Z FE2 GM3 G80 G92 J65 KC4 K34 K68 LB9 MK6 MM5
NP5 N33 N65 N96 PB4 QDZ TR9 TT4 T93 T96 VA1 VQ1
U25 U26 U29 U75 U79 VAN VK3 V73 WW3 W62 YR1 YS1
Z28 1AY 1SC 15P GZW 7ZW 8NL 81A 82C 82I 829 87Q
9NL
Last line of the RPO codes
B6Q
E7Z
NA5
UX1
YT1
87U
Ok well I don't want to type that ever again. Hopefully it says I have a 1LE car or something. Thanks for the help guys.
Old Sep 27, 2005 | 10:01 AM
okfoz's Avatar
9NL
B6Q
E7Z
NA5
UX1
YT1
87U
Unfortunately no its not an 1LE, but you have several goodies, like the G92 (performance gear) should be 3.45 or 3.42 ratio with the LB9 5 Speed, Posi, Rear Disc Brakes. Unfortunately not being a 1LE it does not have factory T-tops, I think the T-top would bring a little more.
Red Car with Red Interior...
Basically a pretty typical IROC hard-top Camaro with the LB9/M5 fortunately it has the G92, which would help to those in the know. Its fun to hope tho.
John
Old Sep 27, 2005 | 11:18 AM
Car: 88 IROC
Engine: 305 tpi
Weird about the color. My exterior is gray metalic and the interior is gray as well. Deff. not red or ever was from what I can tell.
Old Sep 27, 2005 | 12:22 PM
okfoz's Avatar
Your right, 87 & 82 are Gray colors, I was thinking of 74 & 72, my mistake.
John
Old Sep 27, 2005 | 12:58 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Very modified well optioned Iroc! Sounds good!
Old Sep 28, 2005 | 11:22 AM
Car: 88 IROC
Engine: 305 tpi
Ya the car is awesome, I was really hoping it was a real 1LE car. Oh well it has more mods than I have the patience to type and it seems that I find new stuff everymonth. Thanks for your help, I will get some pics up on cardomain and list the site later. I ran it at union grove this summer and it ran a 13.52 @ 103.5 with a 2.0 60ft. time. This is a 305!! No one belives me.
Old Sep 28, 2005 | 11:38 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
With good bolt ons, a good driver, good track conditions, and good traction... I believe it! I was close to that with my Iroc-Z 305 TPI; my best was 14.1.
Old Sep 29, 2005 | 02:39 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Nice find. It sounds as though its been modded tastfully, what a great find. Hopefully the price was right!
G92 on my '88 IROC with a T5 gave me 3.08 gears posi. I believe that code also gave me an aluminum driveshaft, which is huge.
Old Sep 29, 2005 | 03:15 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
It has the 3.45 gear unless someone swapped it out, that's the GM3 code. The KC4 code is the one for the engine oil cooler.
Linson
Oct 24, 2025 02:00 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
