early third gen gauge cluster question
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I know that in 1984 all Firebirds had red backlighting. I have a cluster from an '84 and noticed that the needles are also red, compared to my '82 needles which are white. Just wondering if the '84's only had red needles or were they also available on the '83's? I know that Daytona's had red backlighting also, so those would be excluded.
Basically if a gauge cluster has red needles does that mean it is either from an '84 or Daytona and therefore backlit red??
Also, '84 was the last year of the mechanical speedometer correct? Didn't they change the design of the cluster gauges and go to electrical speedometer in '85??
Also, what would an '84 TA redline at vs. a V6 Firebird?
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
1984 had yellow needles with red backlight. If the needles are actually red it sounds like somebody painted them. 1983 also used yellow needles but the greenish-blue backlight(except for Daytona) 1982 is the only year for white needles.
1985 is the last year for the mechanical speedo. The gauge cluster is basically the same design except for different silk screening on the gauge faces.
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Re: early third gen gauge cluster question
A 6000 rpm for the LG-4, and a 8000 rpm for the L-69.
And to be more accurate, the 1984 gauge back lighting were ORANGE, not red. It is even printed that way on the inside of the gauge bezel, which looks like was molded that color, then had the outer face painted black.
Leon.
Car: 1982 Trans Am
Engine: SBC 400
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Originally posted by ws6transam
Leon,Is that a custom stenciled speedometer?
Yes
Go here, https://www.thirdgen.org/techbb2/sho...hreadid=320180 to learn more
Leon.
Rock on!
I took a whole cluser from a 1987 Trans Am with 140 MPH unit and swapped it in. It took the repinning of 19 wires and several splices to make it work, and I did it in conjunction with the retrofit of the auto with a T56 manual. However, I preferred my old gages.
160 MPH would be nice though, I pegged the 140 unit on the road course earlier this spring and see nearly 120 before dropping onto the brakes at the end of the quarter mile.
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Did you find any problems with the battery charging when you did your gauge swap? I'm thinking about exchanging the warning lights for the gauge package on my 85' but the charge light is apparently what starts up the alternator.
Engine: 2.8 LB8 HO
That's good to know. When I do my warning light to factory gauge swap, I'll need to re-pin both the connectors for the cluster, swap out the oil pressure and water temp switches for the senders, and run a wire in to provide the ignition feed for the tach. I'm also going use my old speedo in the 85' rally gauge cluster. I'm assuming that the speedometers can be interchanged between the idiot light cluster and the gauges cluster considering they both are cable driven. The only difference is the gauges speedo has a trip odometer. I want to keep my original one so the mileage total will stay correct.
I have changed all of mine, when I swapped gauges, to keep the true mileage correct to the vehicle.
Leon.
Engine: 2.8 LB8 HO
How many 82' to 85' Firebird owners have swapped out their idiot lights for full factory gauges? I'm trying to get all the loose ends covered before I try this exchange. I've seen no real tech procedure for this swap involving Firebirds, although it seems a lot of Camaro owners have swapped clusters on these boards.
