rear axle decoding??
Old Nov 17, 2005 | 06:25 AM
captainquad's Avatar
Car: 1985 iroc
i have a 1985 iroc that came with a 5 speed and a 305 (LG4). I am trying to find out what my axle stamping code means but cant seem to find out anywhere? It goes like this
9PD C10 9 2
Any help would be appreciated.
Old Nov 17, 2005 | 07:17 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Forget the stamped numbers on the axle tube, Mfg info. Check your RPO codes for the Gear ratio that was stock for your car.
Old Nov 17, 2005 | 08:39 AM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
I can decode for you tonite.
Old Nov 17, 2005 | 10:12 AM
Car: 1985 iroc
The only reason why I am asking is because I have been doing research and I cant seem to find these numbers for the '85? It seems that this rear end might be from another year camaro? Or maybe it's just me? LOL
Old Nov 17, 2005 | 12:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Can't help with decoding. My 85 IROC (LG4, T-5) had stock 3.23's.
JamesC
Old Nov 17, 2005 | 03:00 PM
Car: 1985 iroc
I took off the diff. cover and it is a 7 5/8" rear end with a 3.23, and I believe it is a non-posi, because I didnt see andything in the middle of the carrier except for the 4 little gears and a center pin, there is no spring in the middle, I guess that would make it a non-posi?
Old Nov 17, 2005 | 03:57 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
http://www.hioutput.com/tech/ratio.html
But it doesn't show a 9PD code either.
The remaining nembers and letters are date and location codes.
Old Nov 17, 2005 | 04:59 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Sounds like someone swapped the rear out. It should be a 3.23, maybe a posi, maybe a open diff. Those codes are
6JH - Std.
6JZ - Posi
6KZ - Posi
6PZ - Posi
Old Nov 17, 2005 | 10:31 PM
Car: 1985 iroc
well its definately not a posi, that sucks, ohh well time to upgrade...lol, found a 9 bolt posi with disks for $300? Sound good?
Old Nov 18, 2005 | 05:38 AM
DJP87Z28's Avatar
Only if its a 1989 9-bolt with the 11.655 rotors & PBR aluminum calipers. All are Limited Slip with these ratios 2:77. 3:27 & 3:45.
Old Nov 18, 2005 | 05:52 AM
Car: 1985 iroc
I was thinking just to upgrade what i have, so I was wondering....if there are 26 spline axle shafts in there now and a non posi, can I put in 28 spline axle shafts and a posi differential? If so do I have to get different bearing due to the fact that the axles would be thicker? What needs to be done to convert to this? Thanks
Old Nov 18, 2005 | 06:54 AM
Klortho's Avatar
Car: 1987 GTA
I give $170 for my 9 bolt with all the calipers, brake lines, e-brake cables and with 3.70 gears
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
