trany info needed
Old Dec 8, 2005 | 11:58 PM
24300's Avatar
trany info needed
i am thinking about bying a 88 and 84 the 88 do not have a engine or trany. the 84 has engine v6 2.8 i think and 4 spead with onerdrive what i need to now is will a will a 350 bolt up to the trany or will i need a new belhosing or will i need a beter trany.
Old Dec 11, 2005 | 10:06 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hi, welcome to the forum,
a 350 engine to the (i assume)700r4 in the 84 wont work
2.8 is 60 degree, 35- is 90 degree
be careful with that 84
i would move this thread to proper forum but i cant
hmm
good luck
Old Dec 12, 2005 | 10:16 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
THe Bell housing for the V6 and the V8 re different, so you would need to find a trans from a Chevy V8.
Even if you get the housing to work I have read that the transmissions are slightly different on the inside, and putting a V6 trans with a V8 is not recommended.
John
IROCZ1989
Jan 24, 2016 03:55 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
