'92 RS RPO Clarification
Car: '92 RS
Hi, was bored tonight so I decided to decode my RPO's Surprised
The majority of these are relatively self-explainatory, however I'd like to know more about these codes. I was told the car was rare, not that it matters to me, but I'd like to know what, if anything, makes this car rare in particular.
B18 ORNAMENTATION, INTR, DELUX - Different seat style?
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE - 91-92 GFX?
E5Z SPEEDOMETER ADAPTER (DELETE)
E9Z SPEEDOMETER KEY (DELETE)
D42 SHADE, RR COMPT SECURITY
D86 PAINT, TWO-TONE, DELUXE - Were the gfx painted a different color originially?
1AY STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1SC OPTION PACKAGE 03
Oh, and it's not the Z03 Package as far as I can tell... Thanks!
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
the 1AY simply means the dealer ordered the car specialy equiped. for example a TA without gfx. or a 2.8L with a "power bulge" hood (true story, not me though)
can't help ya on the rest.
Car: '92 RS
Re: '92 RS RPO Clarification
After a search...
I'll have to double check the RPO codes E5Z and E9Z. Just sounds odd to have thoes options deleted. As far as the 1SC option, was there anything else in this package? Also, is there a way I could possibly find out what the original two-tone paint job was? Thanks!
Originally posted by purg3d
B18 ORNAMENTATION, INTR, DELUX - Different Seats (cloth vs vynl)
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE - Plastic Trim Piece along the side (door guard)
D42 SHADE, RR COMPT SECURITY Retractable Cargo Cover
D86 PAINT, TWO-TONE, DELUXE - 2 TONE w00t
1SC OPTION PACKAGE 03 Automatically adjusting rearview mirror
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
The speedometer RPOs are correct. I have the same ones. I think it has something to do with having a VSS instead of the cable.
About the paint, check for the codes that begin BCCC (base coat/clear coat) then WA. They should be on the RPO sticker or maybe in the driver's door jam. One of the codes following this will have a "L" (lower) and one will have a "U" (upper).
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
e5z & e9z are delete options because your car has an eletronic speedo. There is a signal sent from your trans to your ecm then signal is sent to the VSS (vehicle speed sensor) and that changes signal and sends it to your gauges as an electronic signal which is displayed by the needle on your speedo....instead of old style where a cable connected to your trans came up to back of gauge
d42 is either the pull out shade that covers the rear compartment or the latch down piece that goes over the rear well area...i forget which one that option is...
1ay means a dealership ordered the car, not a special order by a customer
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
