Any f-bodys with aluminun heads
Old Sep 18, 2000 | 03:41 PM
CanadianBeast's Avatar
Did any thirdgen come with the corvette aluminum L98 heads, and if so what it the RPO CODE for it.
Old Sep 18, 2000 | 04:35 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Nope, 3rd gens never had the L98 Corvette aluminum heads. Thats why people look at me funny when I call a 350 TPI a B2L when its in a 3rd gen. That was the difference between the 2 engines: L98s had aluminum heads, B2Ls (and LB9s for that matter) all had cast-iron heads.
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic/AT, T-tops, all power
Hypertech chip, 2 K&N filters/Modded air box
Eclipse CD, Eclipse 100x4 amp, Boston plate 4x6, Boston RX 6x9
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Sep 18, 2000 | 06:18 PM
Then why is my rpo code a l98 and not a b2l
Old Sep 20, 2000 | 09:27 PM
Jason E's Avatar
Uh, I guess I gotta go to Willie on this one.....
BUT, what year is your car?? I'm looking through my code book, and I see no L98 listed for ANY year 350 Camaro. The only L-codes listed for '87-'92 are the LG4s, LB9s and L03s. Sure you don't have an LB9?? The code book shows no listing whatsoever for an L98 RPO.
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic/AT/T-tops/all power
Hypertech chip/2 K&N filters/Modded air box
Eclipse CD/Eclipse 100x4 amp/Boston4x6 plates, 6x9 RX 3 ways/ALL Monster's goodies
Old Sep 20, 2000 | 09:28 PM
Jason E's Avatar
Is it possible Canada had a different RPO system? I wouldn't think so, but can anyone shed some light on this?
Old Sep 22, 2000 | 11:21 AM
back to top
Old Sep 22, 2000 | 11:53 AM
I just rechecked my codes and both B2L and L98 are there. Sorry for the confusion. Is this the way it usually is, with both codes representing one engine?
Old Sep 22, 2000 | 07:33 PM
Jason E's Avatar
Honestly, I don't have a clue....but I'd like to know the answer to that one as well.
Old Sep 23, 2000 | 08:38 AM
Mark 89Formula's Avatar
I can back up the two code designation for the iron head TPI 350. My original factory invoice lists these two line items.
B2L 5.7 LITER FI V8 ENGINE $1045.00
L98 5.7 LITER FI V8 ENGINE (no price)
The service parts identification sticker in the center console also lists both codes. I too have always wondered why GM used the dual code designation.
89 Formula 350, Accel Tri-Ys, 3" SLP, chip, Jacobs, SLP cold air, Probuilt tranny, Vigilante, 3.27s, Spohn torque arm & LCAs w/brackets, GW Subs
Old Sep 24, 2000 | 09:32 AM
Jason E's Avatar
Thanks for the info Mark. Learn something new every day!!
Old Sep 24, 2000 | 01:44 PM
eastbayrallysport's Avatar
also, the L98 was a 4 bolt main while the b2L was a 2 bolt.
Old Sep 24, 2000 | 02:19 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
From what I understand, it was the aluminum L98 corvette engine optioned in the F-body BUT you must get the B2L option. This RPO code swapped out the real L98 for the B2L heads. So basically the SPID sheet is saying you have an L98 short block with B2L heads.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Sep 24, 2000 | 03:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uh uh... the Corvette L98 was a two-bolt main as well. So was the LT1. But the LT4 was 4-bolts, from what I remember.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
92projectcamaro
Jan 18, 2016 08:00 AM
Uglybronco
South Central
Oct 25, 2015 09:22 AM
z28guy134
Sep 1, 2015 11:50 PM
zayne0
Aug 24, 2015 07:22 PM
