what GM should do w/ Fbody
GM: I promise I'll buy a new f-body as soon as I'm out of college. If you cancell production, I'm movin to Ford. There is no way I can afford a $25-35grand car now.
What GM doesn't realize is that they need to make the F-body cars more livable. HEll make em out of the Monte Carlo platform, just make em swoopier, wider, and sportier.
Who do ya see driven Monte's. Older people in their late 30's or so. Same with most
hi-po F-bodies. Why not scrap the Monte Carlo's and just build the Fbody's on their platform. Monte's are taken the custumors away from the Fbody's. Monte Carlo's are coupes too but have no nuts. Make a liveable, more affordable F-body with the same LS1 or maybe LS6 engine.
Oh ya GM have ya thought of ever advertising?
1989 Iroc-Z. 305TPI 5spd, G92 (230hp/300ft/lbs). 91-92Z28 groundeffects. Corvette Admiral Blue Metallic paint. Thermomaster chip, 160*stat & fan switch, Bosch +4 plugs, MAF screens removed, custom ram air, Flowmaster cat back, K&N, adj. fuel pres. reg.
72,000 miles. SWEET!!
Who do ya see driven Monte's. Older people in their late 30's or so. Same with mosthi-po F-bodies. Why not scrap the Monte Carlo's and just build the Fbody's on their platform. Monte's are taken the custumors away from the Fbody's. Monte Carlo's are coupes too but have no nuts. Make a liveable, more affordable F-body with the same LS1 or maybe LS6 engine.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Uh, you can't make an Fbody on the Monte/Impala platform, unless you want it to be FWD!!
Supposedly GM COULD make this platform into a RWD, but the cost of doing so makes it out of the question. Cost is the same reason they won't continue the current platform, either.
I agree they need to make the car more livable if its going to survive. Supposedly now there's a 5th gen prototype thats a V8/RWD that's a 2 door coupe instead of a hatch. I would guess it's built off the next gen Catera platform, as they originally planned?
Have you guys seen the next-gen Firebird? Check out this month's Motor Trend. That Opel roadstser? MT says that its very possible that when the '04 Camaro rolls out, the Firebird will still be non-existant, being replaced by a 2 seat, 4 cylinder Opel-based roadster.
Anyone remember the Fiero??
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm w/ Keyless entry
IROC tailights/tinted windows
Jason E
'89 Camaro RS 2.8
Sorry, I was gonna reply to your post but then it said im not a known member and erased everything I had written and....**** it.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
TB Coolant bypass
Car: C1500
If they used the monte carlo platform, then it wouldn't be an "f-body". And I have heard that they are thinking about taking the monte carlo platform to rear drive.
Of coarse they think of a lot of stuff.
1985 Camaro IROC-Z LB9
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
-180 degree stat
-Hooker Cat-Back
86White_T/A305
Sep 21, 2015 05:28 PM
