not so special, I think?
Old Nov 28, 2000 | 01:54 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I'm the second owner of a 91' Z-28 comaro, the first owner worked at the local chevy dealership. If it's a 1LE, would it be printed on the list with all the other codes.It has 36mm front & 7/8 rearsway bars ,dual cats,G80-G92 rear end, B2L, only thing I'm missing is the aluminum drive shaft,and the bigger front calipers.
Old Nov 28, 2000 | 07:21 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
The only way to tell if it is a regular Z is if you don't have all of the following:foglights,a/c,door moldings,aluminum driveshaft,heavy-duty front brakes, spare tire w/aluminum rim,special shocks,fuel pickup and gas tank.Although you could still have a/c in some cars.If you got what I listed then you have a 1LE.My Z has the options you have.
Red 1991 Z/28 350TPI
minor mods:MAC exhaust,headers,,K&N filters and others possibly(bought used).
John Soule' member of the GULFSOUTH FIREBIRD/CAMARO CLUB (NEW ORLEANS)
Meguiar's wax!
http://www.umount./thirdgen/rides/johnsoule/images/johnsoule1.jpg
[This message has been edited by 91Zman (edited November 28, 2000).]
Old Nov 28, 2000 | 07:47 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
1LE *should* be on the RPO code sticker mixed in with the other codes.
To be a 1LE, it's *gotta* have the large rotor brakes with the aluminum PBR dual piston calipers.. That was one of the *major* things that made a 1LE a 1LE..
1990 GTA L98/4L60
Old Nov 29, 2000 | 11:08 AM
mont1le's Avatar
Like GTA JIm said all the special equipment has to be there not just some.All the 1LE cars that I have seen including mine that were for USA sales, do indeed have the RPO 1LE on there and is also on the build sheet if you have 1,for more details go to WWW.1LE.net there you will find a lot more info.
Leo
92 T/A 1LE
77 T/A 455
92projectcamaro
Dec 8, 2015 12:25 AM
1992Z28!
Nov 19, 2015 07:33 AM
Jsapp38
Nov 13, 2015 07:38 PM
Thaney9
Oct 24, 2015 07:26 PM
Bradsaundry
Oct 7, 2015 04:35 PM
