What gears could have come in a 91 Formula?
Old Dec 19, 2000 | 10:51 PM
Jay'89iroc's Avatar
I might be buying a posi out of a 91 formula, the rpo code sticker is gone and the drive shaft spins just over 3 times to one turn of the tire, it has a L98 with dual cats,10 bolt posi disc with PBR calipers (dont know if this helps). What gears are in this, 3.08 or 3.23????
"89 IROC-Z 350 TPI K&N,no screens,air foil,TB coolant bypass,AFPR@46#,MSD6a ignition,Flowmaster,2.77 gears. Best E.T. 14.60 @ 93 MPH.
Old Dec 20, 2000 | 11:14 AM
mont1le's Avatar
They are 3.23s all L98 cars came with 3.23s so is most likely that unless some1 changed them.
Did you check to see if the car is a 1LE look at the brakes, aluminum spare.
Leo
92 T/A 1LE
77 T/A 455
Old Dec 20, 2000 | 11:20 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
They should be 3.23s. To confirm, your engine should be turning about 1,850 rpm @ 60 mphs in 4th gear with 3.23s.
Old Dec 20, 2000 | 11:47 AM
theformula's Avatar
Car either sounds G92 or 1LE (or both). Check it out.
The front brake rotors will be about 12". Dual piston calipers. Power option delete.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
Old Dec 21, 2000 | 05:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Where did 1LE come from in this post? All rear disc brakes in 89-92 are the PBR calipers. And your rear should be 3.23's, since 3.08's were never offered with an L98. Buy it if its in good shape.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 21, 2000 | 05:34 PM
Jay'89iroc's Avatar
I bought it and you guys know your stuff, they are 3.23's, soon to be 3.73's...Thanks for your help!!!
'89 IROC-Z 350 TPI K&N,no screens,air foil,TB coolant bypass,AFPR@46#,MSD6a ignition,Flowmaster,2.77 gears. Best E.T. 14.60 @ 93 MPH.
junkcltr
Aug 2, 2019 11:12 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
hectre13
Aug 26, 2015 08:17 AM
