1987 IROC Convertible ASC model....
Old Jan 28, 2001 | 07:45 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Just wondering if anyone knows the number of the ASC cars made? (the sixth digit in there VIN is a 2)
"I have done some research and I found some info that said that hardtops were sent to ASC to make them convertibles. and my car has the ASC logo on the square panel where
the defrost switch was is on the coupes(located under the cig. lighter)
Whether it makes a difference or not the top is not power it is manual."
Quote from owner of the car.
[b]My site http://www.camaro3rdgen.20m.com
Old Jan 28, 2001 | 08:54 PM
89RagTopRS's Avatar
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
Factory total numbers are around 28,183. Remember ASC also did do custom jobs for "special customers" in previous years as well as the years the convertible was produced.
According to my sources the sixth digit is a 3 for convertibles and 2 for hatchback coupes.
All tops are manual like yours and mine.
1989 Camaro Convertible
dark silver w/black top
305tbi, auto, all stock
posi
Check out Phil's Rice Boy Page
Old Jan 29, 2001 | 05:13 PM
AAustin50's Avatar
Does anyone know if ASC installed power sunroofs for custom factory orders? My '87 RS has one and it looks like it was professionally (factory) installed. I've yet to see any other 3rdgens with a sunroof.
[This message has been edited by AAustin50 (edited January 29, 2001).]
Old Jan 30, 2001 | 02:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Can't answer for ASC, but there are plenty of sunroof companies that do great work on power sunroofs. I don't think GM offered any, though.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Old Jan 30, 2001 | 07:01 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
3rdgens never got sunroofs...
would be a nice cross between t-tops and ragtop though..
Webmaster: www.IROC-Z.org
Old Jan 30, 2001 | 08:19 PM
Guest
Guest
Posts: n/a
ASC stands for: American Sunroof Company
You tell me if they ever installed sunroofs
Im sure they did some 3rdgens, but whether or not yours was done at ASC is another question. They usually put a sticker on the car somewhere.
Old Jan 30, 2001 | 09:34 PM
AAustin50's Avatar
Yeah, hard to say whether it was done at ASC. All I know for sure is that it is an ASC sunroof and the car is originally from Calif.
If anyone's interested, here's a link to their website.
Old Mar 16, 2011 | 01:02 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: 1987 IROC Convertible ASC model....
I have a 86 Iroc with sunroof, looks like factory also. Have you found out any more info? I am curious also. Let me know
Old Mar 16, 2011 | 07:24 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No factory sunroof in 3rd gen. Hardtop, T top or convertible only.
Old Mar 17, 2011 | 08:57 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
the ZF was an ASC creation that had a sunroof and a woodgrain dash.
ASC made around 400 Camaro Convertible conversions from 1985 - 1987 for Chevrolet dealers, and 600 1986 - 1989 Firebirds for Pontiac Dealers.
Unlike other conversions, such as Matrix, hi-line, autoform and other aftermarket conversions, parts are identical to the factory models... Arguably ASC conversion cars do have advantages. You could simply go to a dealership and order your parts, Firebird or Camaro...
Sometimes the aftermarket ASC convertibles actually got nicer parts, than the factory models, I have read about electric pull downs for the tonneau & such.
John
Old Mar 18, 2011 | 02:32 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Originally Posted by Joe_L
"I have done some research and I found some info that said that hardtops were sent to ASC to make them convertibles. "
It was the t-tops that went to ASC.
Old Mar 18, 2011 | 09:05 PM
okfoz's Avatar
IrocTopless is correct, ASC only converted T-Top cars. T-top cars were ideal to convert due to slightly better structural characteristics in the floor. Also a special garnishment would not have to be made as in the Riviera, Eldorado, Sunbird and Cavalier convertibles as the sheet metal was stamped out for the weather seal by the windshield.
ALL 3rd and 4th Gen's started life as T-top cars and were converted as per ASC design, regardless of the 2 or 3 in the VIN. The 3rd Gens were done off site at ASC, the 4th Gens were moved to another plant (in Canada) so that the convertible conversion was done on site, the parts were supplied by ASC.
John
Old Apr 1, 2011 | 11:07 PM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
About this controversy factory sunroofs. I have an 92 25th z28 myself and called local dealer about vin and whether or not was factory sunroof and they said yes they had some with factory sunroofs . very rare though.no numbers to speak of for pro numbers.
Old Apr 1, 2011 | 11:25 PM
Engine: MPFI
Do you have a picture of the car? would love to see how it was done! Thanks
Old Apr 2, 2011 | 01:52 AM
Drew's Avatar
A sun roof wasn't a factory option on 1982-92 f-bodies. You won't find an RPO code for a sun roof in any of the normal books, or resources. However, if you wanted a sun roof, the dealer could send the car out before delivery, have someplace cut a hole and install an aftermarket sun roof. Likewise, you could buy sun roof kits from JCWhitney and the like, and install them yourself.
Old Apr 2, 2011 | 07:38 PM
okfoz's Avatar
To my knowledge, GM never installed a manually operated pop-up sunroof in any car. Since the mid 70's When GM cut holes in a roof they were a powered MOON ROOF, or T-tops, or a convertible. Actually when GM put the hole in the top they actually stamped the sheet-metal special instead of simply cutting a hole in the roof. The easy way to tell whether or not GM did the actual work would be by how it was installed... Look at the opening around the cutout, If there is a black trim piece that attaches to the roof of the car, then it is 99% chance it is aftermarket. However if you open the top and see that it is painted body color inside the opening then it would be a factory moon roof.
Side note... When the guy that designed the Moon roof was asked why he called it a moon roof, he said, "because you could stand up and moon the guy behind you." Its a local lore actually...
In retrospect I want to think that the Fiero may have had a manual pop-up roof option... The only car I can think of that may have come from the factory with it... Of course it might have been aftermarket.
Old Apr 3, 2011 | 04:13 AM
Drew's Avatar
Yep... They pop up, or they can be removed completely and stored under the "hood". The storage compartment actually has molded supports so the glass sunroof can be set in the compartment. Later Fiero's got fancy and some had a bag sort of like our ttops, and then the whole deal set in the storage compartment under the hood.
Old Apr 4, 2011 | 12:17 AM
Jeff Fowler's Avatar
Berettas were also available from the factory with a manually operated pop-up sunroof.
Old Apr 4, 2011 | 12:48 AM
puma1552's Avatar
John
I thought no convertibles were available through dealers whatsoever until 1987?
Out-Cast
Dec 31, 2015 04:40 PM
g.l.mos
Aug 22, 2015 12:02 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
