Here's one for the pro's
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Looking for production numbers/rarity of the following car:
1991 Pontiac Firebird Trans Am WS6, lexan t-tops, lb9/auto w/ aluminum driveshaft, 2.73 posi rear with alum. drums, all power except seats, leather wrapped steering wheel/****/handle.
RPO codes (with the definitions I could find):
AAA : 4-WAY MANUAL SEAT ADJUSTER
AH3 : ADJUSTER, 4-WAY MANUAL, DRIVER SEAT
AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DE4 : SUNSHADE, REMOVEABLE HATCH ROOF
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D7C : GEAR, SPEEDO DRIVEN
D8N : SENSOR, VEH SPD
D81 : SPOILER, RR, AERO WING
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GU2 : AXLE REAR, 2.73 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
IPC : TRIM- INTERIOR DESIGN
JG1 : SHAFT, PROP, ALUMINUM
J42 : BRAKE SYSTEM, PWR. FRT DISC, RR DRUM, ALUMINUM
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
PW7 : WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
Unable to locate code R9Z in our database!
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UQ1 : RADIO PROVISIONS, FOR STEREO
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
U62 : SPEAKER SYSTEM, DUAL COAXIAL
VAN : ASSEMBLY PLANT, VAN NUYS, CA
V73 : ANTENNA, FIXED
WS4 : MODEL CONVERSION, TRANS AM
WS6 : PERFORMANCE PACKAGE, SPECIAL
Y83 : MERCHANDISED PKG, TRANS AM
1SC : PACKAGE, OPTION 03
1SZ : ???
18P : WHEEL COLOR, CHARCOAL MET (91)
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
81Q : MOLDING COLOR, BRIGHT RED (91)
81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
T96 : LAMP, FOG
1SZ : ???
I'm not going to tell you the production numbers for every option on your car, if you want to do that yourself, you can go buy a book and find out. However, your car doesn't sound very unusual... The only thing that really stands out is the aluminum driveshaft.
7,034 TAs were built in 91. That figure includes 555 convertibles and 2,035 GTAs. So that leaves 4,444 TAs. I have no idea how many were WS6 and what not. I agree with DREW also that the only standout option is the ALUMINUM driveshaft which is about the only RPO my car doesn't have on it.
Hope this helps ya out man.
92 Trans Am WS6
92 Trans Am WS6
Guess I wasn't looking for exacts, nor for the #s on every rpo, I just put them in for a reference. Everything you all have given me is fantastic!! Thanks!
Chris
Chris
Pinguiclia
Oct 12, 2015 04:47 PM
