HP for 87 gta 305 5spd 3,42 posi
Car: 89 Formula
Transmission: TH 700R4
205 hp @ 4400 rpm 285 LBS @ 3200 rpm-
That torque might be wrong but I'm pretty sure the rest is right.
The air cleaner set up is very restrictive, a 5.0 TPI IROC is 215 hp (5speed).
I think high 15s in the 1/4 GTAs are pretty heavy. But at least you have "the good cam"
88 TBI IROC- mods- 5500 rpm redline tach, 240 KM/H speedo,
L69 air cleaner (installed someday
205hp@4400rpm 270ft/lb@3200rpm.
1/4mile 15.2@91mph
BTW,you have 3.45 gears not 3.42's.
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,
SLP Package,SLP Torque Converter/Shift Kit,Fastchip,GSC's
G-tech 0-60 5.1 1/4mile 13.6@104
member www.transamgta.com
Previous Thirdgen
1986 Camaro IROC-Z
1/4mile 15.2@91mph
Previous Thirdgen
1986 Camaro IROC-Z
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I'm not sure about the years but the post 1987-88, 305 TPI,stick cars had somewhere between 210-230HP, depending on if it was a single-cat or a dual-cat car. Add 5HP for Chevys due to a cold air set-up.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46), Harwood fiberglass hood,original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch (going).
1990 Formula
Dual cats weren't available till 89. If the car has a 9 bolt rearend it has 3:45's. 3:42 is a GM ratio.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6Sold
92 S10FOR SALE!
98 Grand Am GT
Drew
My Website
87 Iroc
91 RS Convertible
91 Firebird V6Sold
92 S10FOR SALE!
98 Grand Am GT
Car: 4
Engine: 6
Transmission: 5
Not too many 87 GTAs would have 3.42s... those are available in the 10-bolt. Most GTAs came with a 9-bolt, for which that ratio is unavailable. 3.45 was the equivalent one that was used. I take it your rear has been swapped at some point.
ICON Motorsports
ICON Motorsports
Maybe i should read the title before i post. For some reason i thought it said '85.
I have a '87 IROC with 5 speed, 3.45 limited slip rearend. It is rated at 215 hp. The gta was rated at either 205 or 210 hp. in '87.
ambainb
Apr 25, 2016 09:21 PM
