DO I HAVE MY ORIGINAL ENGINE?
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
WHERE DO I LOOK TO SEE IF I HAVE MY ORIGINAL ENGINE? DO I MATCH THE VIN # WITH SOMETHING ON THE ENGINE. ALSO HOW DO I CHECK MY TRANS TO SEE IF IT IS THE ORIGINAL? IF MY ENGINE IS NOT ORIGINAL IT WILL MAKE ME WANT TO SWITCH TO A 5.7 SOONER THAN PLANNED. THANKS IN ADVANCE.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
What's up Andre? Hey, if you want to come by this weekend we should be able to figure it out. I'll be home all weekend, I'm parting out the IROC and the maroon Trans Am. You can also pick up that cargo cover if you want.
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
The last numbers of your VIn (or sequence number) should appear stamped on a pad on the block. I think it's passenger side just in front of the passenger side head. If not try the drivers side. That number should match. The pad will also contain other numbers infront that tell what engine, when and where it was built etc. The tranny will have similar numbers stamped also.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Axle/Gears: Posi
HEY DENNY, IT'S BEEN RAINING 40 DAYS AND NIGHTS. I JUST GOT ON THE NET AFTER WORKING ALL WEEKEND. I'LL CALL YOU ON TUES TO SET UP A DATE TO PICK UP THE CARGO COVER. CAMARO IS GOING TO PAINT SHOP FOR SOME TOUCH UP WARRENTY WORK AND I'LL HAVE IT BACK LIKE FRI OR SAT. THANKS. I REALLY WANT TO CHECK THIS ENGINE OUT.
colton_carlson
Mar 8, 2019 12:21 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
