87 Formula Questions??????
Old Apr 20, 2001 | 10:05 AM
Rareform92's Avatar
I just bought an 87 Formula with the base 305, automatic, limited slip rear and 4 wheel disc brakes. I've never seen another base engine Formula with 4 wheel disc brakes so is this a correct option? The car is totally stock and only has 45K miles on it, so I don't beleive the rear was changed. Also how unusual are manual windows and manual side mirrors in a Formula? I know they were standard with power being optional. Also no T-Tops. Its a fairly low option Formula. It also has the lower body stripe package around the entire car. Any idea if the majoity of Formulas came with or without the stripe package. I beleive it was a delete option if I remember correctly. Thanks in advance for any help.
Old Apr 21, 2001 | 03:50 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
Congrats! Welcome to the club.
The Formula for '87 came standard with the WS6 suspension and it included the (J65?) 4wdb option. No matter what engine it came with in '87, LG4/LB9/L98, all formulas had the WS6 and 4 wheel-disc brakes. Formulas for '87 did indeed come with (lower-body) accenting with a tape stripe and decals. I'm pretty sure the "stripe/accent" delete package was NOT available for the Formula in that particular year. However, I believe the stripe/accent delete package was offered in the years '88-'90.
'89 GTA: blk on blk with 5.7 liter, T-tops, leather, N10 dual exh with 76,500 original miles. 100% stock including the ZR50 Goodyear "gatorback" tires.
Old May 28, 2001 | 08:27 PM
tbabeck's Avatar
Not all 87 formula's came with the 4 wheel disc brake conversion or stripe kit..I know i have a 87 with drum's and solid med metalic maui blue codes all match.
Old May 28, 2001 | 08:45 PM
Guest
Guest
Posts: n/a
Base engine, being what?
I thought the 4 wheel discs were only available with the TPI but I guess stranger things have happened... The rear discs werent standard and werent a part of the WS6 in 87 (or 86 or 88 for that matter) so it was an option added to your car if in fact it was available with the base engine. Manual window cranks and mirrors doesnt sound unusual. The single color, or delete package, or whatever... Well I drove a brand new 87 Formula with the 350 in August 1986 off the lot of a dealer for a test drive, and it was all red, no stripes at all. It was definitely available with no stripes at all.
Memory lapse...
[This message has been edited by madmax (edited May 28, 2001).]
Old May 29, 2001 | 08:54 PM
Rareform92's Avatar
Hello, I was the guy who originally posted this and after getting the Formula home, I came across the original window sticker in all the paperwork. The J65 4wheel disc brakes is listed as an individual option and was priced at $179, so it is obviously not part of the Formula option and was available with the LG4 305 4barrel engine. I hope this clears things up somewhat. Thanks.
[This message has been edited by Rareform92 (edited May 29, 2001).]
Old Jun 8, 2001 | 12:47 PM
Ragtop Man's Avatar
Back then, you could free-flow almost all the Firebird options, resulting in some pretty wierd build combos.
A stick LG4 with discs and low options sounds like a killer base for a streeter, say with a ZZ4 and some squeeeeeeezeeeeeeeee.
BOB
Old Jun 8, 2001 | 02:08 PM
lallen's Avatar
Why are you selling it?
(The Formula that is on eBay right now!)
Formula Fans:
There is a good photo of the window sticker to document the equipment.
http://cgi.ebay.com/ebaymotors/aw-cg...item=592192100
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
formula1lle
Jan 29, 2016 10:56 AM
lt1z350
Aug 28, 2015 05:57 AM
mrestrictrplate
Aug 27, 2015 09:37 AM
redmaroz
Aug 16, 2015 11:40 PM
