88 formula
88 formula
Just saw an 88 Formula 305 tpi in the junk yard--what a waste!! Car had 3.27's w/rear drums and the n64 spare tire. I thought those only came w/the rear disc cars? Also had the aluminum driveshaft. Car was all original so nothing was swapped. Do you guys think those rear drums are aluminum? Can't get the wheels off so it's hard to tell.
car still has the rpo label in it too.
Also had dual fans--thought that was only on 350 cars? Has the 140 speedo w/the 6000 tach.
they're gonna crush the car on Tues so some info quick!
Thanks!!
Thanks!!
Car: 1990 Formula
Engine: treefitty
Transmission: stick
As far as I know, all Formulas came w/rear disc brakes.Trans Ams of same years could have drums but not Formulas.
4 wheel disc brakes were part of the WS6 package which was standard on all Formulas. Correct me if I'm wrong.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46), Harwood fiberglass hood,original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce dual friction clutch.
1999 Lexus GS 400 everyday car(It's a V8 so its not Rice)
1987 Voyager Minivan. Cost me $300=runs like new.No repairs for over 2 years(fingers crossed)
DIRECT LINK TO PICS OF MY CAR. NO WEB-PAGE. http://community-2.webtv.net/MZavraz...A90/page9.html
1990 Formula
Car definitely had the ws6 package on it--huge sway bars and the ws6 sig on the lower dash(original) When I go to the yard on Tues(before it's crushed) I'll grab the rpo tag.
Car makes me curious tho.
All Formulas had the WS6 suspension as standard equipment but it did not include the J65 4 wheel disc brakes, that was an individual option priced at $179 and was available on any Formula no matter what the engine or transmission. The disc brake option was a required option on the 305 TPI 5spd and 350 TPI Formulas.
Guest
Posts: n/a
Dual fans were available on cars other than 350 cars, heavy duty cooling option. If the drums were in fact aluminum, they were not original. GM used them on G-bodies in the early 80's, but ditched them because of problems with them... which basically amounted to wear issues. The aluminum drums have a strange round button looking thing that is the weight for balancing, and the fins are much larger and stick out farther from the drum itself than the cast iron drums.
I thought aluminum drums were used on Irocs that had the 16 inch rims? Does anyone know the rpo code from the Camaros?
When I go Tues I'll check for those weights and I'll let you guys know what I find.
Thanks for all the help w/my questions.
So I guess Firebirds only used the steel drums then?
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Dude, buy it from the junkyard and save it from the crusher...sell it if you have too!! Sniff sniff....
Jason E
'89 Camaro RS
Medium Grey Metallic
2.8, A4, T-tops, 91k miles
'97 Z28 w/30th Anniversary package
LT1, M6, t-tops
White with orange stripes, killer system, 42k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Jason E
'89 Camaro RS
LT1, M6, t-tops
Long Live #3...
Jason unfortunately I can't, the car has been gutted to hell, harness has been cut and the body is shot to hell!! Dents and scrapes all over the place! Plus the car is like 80 miles from my house, so that would be one hell of a tow for me. For the hell of it I asked how much for it the way it was--he wanted $500-wasn't worth it, only thing that was worth something was the interior-so you know how that goes! Would've been the perfect car for my 350 drivetrain. he wanted $1000 before he pulled the drivetrain.A Day late!!
Ha said he'll wait a day before he crushes it because I told him I needed some more stuff from it--nice guy!?!
Ok here's the vin #-1g2fs21f5jl253340.
RPO's-aaa, ar9, au3, a01, a31, bc8, by4, b67, b84, cc1, cd4, c49, c60, de4, d3v, d34, d35, d81, d9a, e5z, e9z, fe2, gu5, g80, jg1, j50, k68, lb9, md8, mx0, na5, n33, n36, n64, pb4, pe0, qdz, um6, uq1, u66, van, vk3, v73, ws1, ws6, wx1, w66, 1sa, 11q, 12p, 19b, 19i, 199, 40u, 6zx, 7zx, 8nl, 9nl.
Can anyone break down some of these?
Thanks.
Thanks.
