91 RS option decoding
Old Feb 21, 2006 | 06:51 PM
mech187's Avatar
Car: 91 RS Camaro
I have a sticker inside the console on the sidewall that has rows of codes on it. Are these option codes for the car when it was built? Where can I find the information to de-code them. thanks
Old Feb 21, 2006 | 09:22 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
you are correct, the sticker inside the console lists all the options you have, but it wont tell you if your car was ordered with something optional. there should be an RPO decoder on this site but ive heard that its not working...
Old Feb 23, 2006 | 03:59 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
http://www.angelfire.com/ny2/96transam/rpocodes.html
here's a pretty good rpo code list.
Old Feb 23, 2006 | 04:06 PM
2B4CruZin's Avatar
Car: 91 RS Texas B4C
Engine: 305 TPI (M.I.A.)
Transmission: T5 (M.I.A.)
Axle/Gears: 3.42 Posi
Here's a partial list to get you started....
1991 Factory Options
RPO Description
1FP87 Camaro RS Coupe
1FP87 Camaro RS Convertible
1FP87 Camaro Z28 Coupe
1FP87 Camaro Z28 Convertible
1LE Special Performance Components Package
AG9 Power Seat, driver side
AU3 Power Door Locks
A31 Power Windows
A90 Power Hatch Release
B2L Engine, 350ci, 245hp V8 (Z28 coupe only)
B4C Special Service Package ($3,950 with RPO B2L)
B34 Floor Mats, carpet insert, two front
B35 Floor Mats, carpet insert, two rear
B84 Moldings, body side
CC1 Roof Panels, removable glass
C49 Defogger, rear window
C60 Air Conditioning
DC4 Mirror with Dual Reading Lamps
DE1 Louvers, rear window
DG7 Mirrors, electric twin remote
D42 Cover, rear compartment cargo area
G80 Rear Axle, limited slip
G92 Rear Axle, performance (Z28 coupe only
J65 Brakes, power front disc and rear disc
KC4 Cooler, engine oil (Z28 coupe only)
K05 Heater, engine block
K34 Speed Control, with resume
LB9 Engine, 305ci, 205hp (base with Z28)
LO3 Engine, 305ci, 170hp (for RS Coupe)
MX0 Transmission, automatic with overdrive
N96 Aluminum Wheels, 16 inch
QLC Tires, P245/50ZR16 blackwall
QMT Tires, P235/55R16 blackwall
QPH Tires, P215/65R15 all season blackwall
UL5 Radio, delete
UM7 Radio, stereo, clock, seek/scan
UN6 Radio, stereo, cassette, clock, seek/scan
UU8 Radio, stereo, Delco Bose, clock, seek/scan
UX1 Radio, stereo, cassette, clock, s/s, equalizer
U1C Radio, compact disc system with clock
U75 Power Antenna
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
