What are the difference between Iroc foglamps and sports coupe ?
Old Aug 9, 2001 | 09:27 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
My sports coupe orginaly had foglamps.Will the iroc foglamps work and will it look right?
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
Old Aug 9, 2001 | 10:04 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The Z28 and Sport Coupe fog lamps are identical. The difference is the mounting bracket. Also, the orientation is 180 degrees off. On the Sport Coupe, the lamp is mounted upside-down in comparison to the Z28.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited August 09, 2001).]
Old Aug 10, 2001 | 01:17 AM
Blue502's Avatar
Exactly. And if you change your sport coupe over to the gfx style, all you need to do is flip your original lights and brackets upside down, drill a couple of holes in the bumper brace located above, and bolt the bracket up. They fit perfect, but a little deeper in the grille as you can see in pics of my '86.
'86 Camaro Sport Coupe & '88 IROC-Z
StevenB L98/LS1
Aug 22, 2015 09:03 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
