differences in compression
Old Aug 28, 2001 | 03:16 PM
FlameRedMetallic's Avatar
hey guys, what did GM do to change the compression ration of the LG4 engine in 1985. it went from 8.6:1 to 9.5:1. did they change the heads, or the pistons? i may be doing an engine swap with a friend and this will help us decide what we can and can't do with our motor.
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
Old Aug 28, 2001 | 03:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The early low compression LG4's had dished pistons, later ones had the same flat-tops as the L69.
Old Aug 28, 2001 | 04:36 PM
cool thanx for the info. that is what i suspected, so then is there a difference between heads on any 305's? or are they all the same. obviously they switched to centerbolt in 87 but before that there was only one head casting right?
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
43,000 miles
Old Aug 28, 2001 | 06:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All had the same heads.
Old Aug 28, 2001 | 06:41 PM
cool thanx for the info man.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
