Which Engine do i have??
Old Aug 31, 2001 | 12:42 AM
Adams87Camaro's Avatar
When i bought my '87 SC the lady told me the engine was not the original engine, i have no rpo codes because the console was replaced with a console from an '84 berlinetta with a v6, i checked the rpo codes on here this is how i know they're different cause the VIN comes out as an '87 SC with an 8 cylinder. Is there anyway to check if my engine is an LG4 or one of the 305 4bbl H.O. engines?? Thanks for your help.
Old Aug 31, 2001 | 12:45 AM
SCtoSS86's Avatar
take ur vin number and go to the vin number thinger on this site it should say what engine u have becuz i did mine and it said i had an lg4 , the vin decoder thinger is right below the rpo decoder in the third gen home page.
Old Aug 31, 2001 | 12:59 AM
i checked out the VIN number on here it came up as an '87 SC with an 8 cylinder but the lady said its not the original engine is there anyway to know if its an LG4 or the 305 4bbl H.O. (don't know the engine code for that one).
Old Aug 31, 2001 | 05:15 AM
Drew's Avatar
If its not the original engine, you'd need to get the block casting numbers to determine what it is. Chances are its a Lg4 or equivelant. Just about every Camaro I've ever seen that had the motor changed by a shop ended up with a GM goodwrench or another remanned 305 LG4 clone.
Old Aug 31, 2001 | 08:21 AM
The thing that makes me wonder is that some of my friends have cars within the 190-200 horsepower range and i can beat them and they're good drivers, which makes me think its not an LG4, the only mods i have are a flowmaster catback.
Old Sep 2, 2001 | 03:07 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All 1987 carb engines are LG4's, so you dont have the H.O. engine. However its possible you have a 350. The only way to know is to get the block casting numbers off the back of it by the distributor.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
