What finish should the sway bars be?
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Im puting in a 3:45 9 bolt rear and want to paint things the correct color.is the rear sway bar a natural cast iron finish?What color is the front sway bars black.What finish should the front lower control arms be natural or semi gloss black?
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
86 sports coupe lg4 2:73 posi disc brake 3 inch exhaust with some kind of flow master(Dual tail pipes)ugly primered Z28 or iroc front bumper.
If you are looking to put yours back to stock looking. The front LCA's were unpainted, the sway bar is flat or semi-gloss black. At least they were on my RS & Iroc. Sway bar links come unpainted.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
Thanks for the info!
darwinprice
17
10-11-2015 11:51 PM
