84 Trans Am L69?????
Old Sep 5, 2001 | 11:38 AM
Rareform92's Avatar
I found an 84 Trans Am and it has a letter G for the engine code in the VIN#. Is this for the L69 190hp motor. Car has a 5 speed in it. It also has an air induction system on the underside of the hoodscoop. Was that only an L69 item or available on other TAs. Anything else specific to the L69 cars that I should look for?
Thanks in advance for your help.
Old Sep 5, 2001 | 01:21 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
The functional hood scoop was available on LG4 T/A's too (both of mine have/had it).
HTH
83 T/A, 84 T/A, 94 T/A, 94 25th anniv T/A, & Some fords.
Old Sep 5, 2001 | 08:48 PM
Cosmik Debris's Avatar
Larger exhaust.
Old Sep 5, 2001 | 09:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is the correct VIN code for the L69. If it really is one, it will have (or at least would have come with) 3.73 gears, an electric fan, and the catalytic converter with the 4-bolt flange at both ends, with the enormous oval Y-pipe. You should be able to get an immediate clue when you drive it too, if it runs anywhere near right; the butt dyno difference between the LG4 and L69 is quite noticeable.
ICON Motorsports
Old Sep 6, 2001 | 01:28 PM
TA76's Avatar
Concerning L69 84 TA's: I was under the impression that all 84 TA's came standard with the L69 engine... is this true or false?
Old Sep 6, 2001 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be completely false.
ICON Motorsports
Old Sep 6, 2001 | 05:39 PM
Rareform92's Avatar
Here's an update on this particular car.
I mentioned it to a friend and he worked with a guy who owned it a couple of years ago. This guy removed the entire L69 motor, 5spd trans and 3.73 disc rear and put it into a 83 Z28 because the Z28's divetrain was beat to death. Actually he bought a crate motor for the Z28 and gave the L69 as a return core. So the Trans Am now has the 83 Z28 drivetrain in it. The Trans Am does need a complete restoration but without the original drivetrain, I will not be interested as it will be too expensive. Interior is pretty wasted also.
What a waste as this was a beautiful car in its day. White with blue interior, aero package and hi-tech wheels.
I may see if I can buy just the air cleaner and cowl induction system as its still there and appears complete. Any one know how much these are worth?
Old Sep 6, 2001 | 09:52 PM
MNformula350's Avatar
The 305 Cross-Fire injected cars also had the air induction systems, my 83 had it and others i have seen.
84 FIREBIRD-(undergoing rebuild)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top
WANTED:82-84 Firebird 2.5 4cyl,4spd-Just Cause
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Sep 17, 2001 | 03:48 AM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
<font face="Verdana, Arial" size="2">Originally posted by TAdan:
HTH
</font>
Only 83 and up. 1982 LG4 did not have a functional hood.
Also, all LU5's (Cross-Fire) had functional hoods, ECM driven.
1982 Recaro Trans Am LU5/WS6/Y84, 2971.6 original miles - http://ohok.com/82recaro
1985 basic Firebird, LB8/F41/GU6/DE1, '82 T/A wheels, CB, 131k - Get JPG picture here
Hawk312
Aug 22, 2017 08:55 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
