do any GTA's come with glass lensed fog lights?
Old Sep 16, 2001 | 09:44 PM
breathment's Avatar
My fog lights have plastic lenses, and i have seen a coupe other plastic ones, but i have also seen a couple glass ones, wut did they come with stock?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
[This message has been edited by breathment (edited September 16, 2001).]
Old Sep 17, 2001 | 01:21 AM
92GTA's Avatar
Mine are glass.....
www.TransAmGTA.com THE 3rdgen Firebird Site!
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, EVERY available option except U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
Old Sep 17, 2001 | 07:42 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Hey, man... it was great to meet you this past weekend at the SWMG!
As per your e-mail, my red '88 GTA has the original glass lenses on it. In fact, all GTAs originally came with glass lenses on the fog lamps. But the prohibitive replacement cost of these lenses (scaring $100 a piece....) have caused many to seek out aftermarket alternatives.
Blazer makes an exact replacement set of fog lamps that will fit a GTA and look original. They do feature plastic lenses, but you really can't tell by looking at them. They're a simple bolt on for our cars, with just a "cut and splice" on the light wiring necessary for installation.
Wal-Mart sells them for $19.95 per set in the automotive department. I have a set of them on my notchback GTA, and you really can't tell the difference.
Hope this helps.
Frankie Rider, 2
The GTA Source Page
'88 GTA Red Hatchback - 5.7L/A4
'88 GTA Black Notchback - 5.7L/A4
'88 GTA Gunmetal Hatchback - 5.0L/A4
Old Sep 17, 2001 | 09:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Actually, those blazers are a whole lot less than a "bolt on" unless you're fortunate enough to still have the factory fog-light casing. Then you can just swap the lenses and the reflecter behind them. In my case, one of my fog lights was murdered; the bracketry and everything was broken. I had to use the entire blazer assembly instead of just the lense, which required custom fabrication. It wasn't hard, but it was quite time consuming. If I was smart I would have picked up a cheap factory assembly with broken glass, then replaced the guts with the Blazer stuff. If you want pics of my Blazer installation, let me know.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 17, 2001 | 10:18 PM
breathment's Avatar
alright, i look really close at them today, and even thought i have taken the lenses off before, i didn't realy pay attention to them, but today i realized that they WERE glass . the reason i guess i thought that they were plastic is because of how foggy and dirty they are, looks kinda like agged plastic, no the only problem is that i have one broken on and one non, and i just hope i can clean them so they will once again be clear, if they ever were. are the blazer brand ones a exact fit? because everything works perfect except for the lense.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 18, 2001 | 10:10 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
My mistake, Jim.... thanks for the clarification.
Old Sep 19, 2001 | 08:09 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FrankieRider2:
My mistake, Jim.... thanks for the clarification.</font>
I knew what you meant, but I was just afraid he didn't.
On a side note, you should have seen me in Wal Mart. I had my entire stock fog light assembly there, and I was opening all of the packages and comparing the lights.
The IROC Homepage
Old May 26, 2003 | 05:23 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
hey sorry to bring back an old post, but i cant seem to find what i need.
i need just the glass lens to replace my broken one on my pass. side fog.
i found the Optronics A16C CLEAR REPLACEMENT LENS FOR HI-16CL AND QH-16CT for just $5.00! but they are sold out at advance auto parts.com. no local parts store seems to have it either.
anyone know where else and what model # will fit as well? (just the lens!)
also, how does the lens fit onto the assembly, simply pop it in?
any help is appreciated, thanks!
Old May 27, 2003 | 01:43 AM
biff85ta's Avatar
Car: 04 Vette
There is a glass lens from blazer as well I found mine at auto zone when I bought my bulbs.
Old May 27, 2003 | 07:21 PM
Car: '89 GTA
okay, this is what i ordered, should i take it apart to get the lens, or how do i just swap the whole assembly in and take mine out?
Attached Thumbnails do any GTA's come with glass lensed fog lights?-qh16ct.jpg
Old May 28, 2003 | 10:15 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
If those lights are like all the others I've seen, then you'll be able to take the screw out holding the light to the original bracket.... then attach the GM bracket with the same long bolt to the new lights. If the bolt supplied is not long enough, then reuse your old GM bolts.
They will mount upside down (bolt to the top of the lens) to how they are mounted now in that photo, though. Then it should just be a matter of splicing in the factory wiring, and you're on your way. Good luck.
Old Jun 5, 2003 | 10:29 PM
Car: '89 GTA
got them, worked just like ya said, thanks for the help!
- deL
jaridjohn
Jul 8, 2024 03:49 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
BrianI
Aug 9, 2015 11:52 AM
