How can you fix roll up shades so that they roll up fast again?
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I recently purchased a vinyl roll up shade. Visually it looks like new but it will not roll up by itself.
Is there a method of fixing this problem?
speed
speed
Car: 1980T/A,1987GTA,1989 GTA conv
Very easy fix!I had the same problem with mine.With the cover installed in the car take the plastic end caps off the rod that goes through the end of the cover then rotate the cover(clockwise if on drivers side)one or two times then put the end caps back on the rod.You may have to take the rod out of the cover,just slides out,but I don't think I had to.Thats it!Mines been working great ever since.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 1989 IROC-Z
Engine: 346 LS6
I understand what you mean but i dont think Duke does. I wiil give it a try and get back to you.
speed
speed
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by speedmachine
hello
I did as advised and my shade still doesnt rool up. Anymore suggesions?
Speed
Speed
If you tried it and it didn't work no wonder, I wish I could make mine work again. I guess I will have to dismantle it, see how it works, fix it and will post a fix for it. Trending Topics
Basically your just winding it up.Creating more tension on the spring inside.The plastic end pieces I'm talking about are about a 1/2 in diameter and fit into the ends of the rod(same rod that the plastic handle mounts to).On my cover those little plastic pieces are the only thing that keeps it from unrolling.
Car: 1989 IROC-Z
Engine: 346 LS6
Yes.... i knew what you were talking about in your first post... it just didnt work for me.. maybe there is an internal problem with mine.
Speed
Speed
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The roll up shades work similar to roll up window shades.On those you can rotate the one end,with the other end installed in the mount or secured somehow to keep it from turning. to add tension to the roll up spring.Fbody is explaining the other way to adjust spring tension.With the cover installed and fully rolled in you rotate the cover in the direction - toward front of car - to add tension to the roll up spring.Now this is trial and error.Go a small amount at a time to keep from overtightening and breaking the spring tensioner.Now as for replacing a broken spring you may be able to use a window shade of the same length.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I will give it a shot and report my good or bad luck. Supreme Member
Engine: LU5 305 CFI
Iron Duke I need to correct the direction to roll the cover.You rotate it toward the rear of the car.Still with the cover fully rolled in.This is how the spring is tension,when you roll it out.I apologize for the mistake in the previous post.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
ABSOMOTHERFRIGGINLUTELYGENIOUS
I didn't know what you meant at first because I don't have the rubber or plastic caps on my rod so I thought you meant the big plastic caps that the shade it self has. I wen't ahead and removed the rod so I wouldn't break the plastic caps, mounted it in the car, rolled it towards the rear of the car 6 times (probably could go more) and it WORKS
Once again I love this site and the great people here.
Engine: LU5 305 CFI
That's great it you both got them working.Again I'm sorry for my booboo at first.I'm glad you saw my 2nd post before you tried the repair.This site is great and how everyone is here contributes to helping each other.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
