Emissions Decal
Old Apr 13, 2006 | 08:11 PM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
Emissions Decal
Can anyone help???
Some Idiot decided that the Emissions Decal, and the metal plate with the paint and other codes were no longer needed on my 86 Iroc 305 TPI (VIN Code F)
Can anyone provide me with any of the following:
a) an acutual correct Emissions decal?
b) an good picture of the correct one?
c) the idiots address that removed this stuff before i got the car?
Old Apr 13, 2006 | 09:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Were they still using cowl tags in 86?
Old Apr 13, 2006 | 09:23 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I dont think they did.
Old Apr 13, 2006 | 09:46 PM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
YEs They were, and there is a GM part Number for it, but is no longer available, and cant seem to find one for the "F" Vin Code Engine (TPI) in the aftermarket, I have Found ones From Clasic industries for the Carb model cars, but are nor correct info for what I need.
Old Apr 13, 2006 | 10:01 PM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
Oops, by cowl tag did you mean the metal tag?
If they werent using them, where can I find the paint codes?
Old Apr 13, 2006 | 10:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, cowl tag is the metal one. Paint codes would be on the SPID label.
Old Apr 13, 2006 | 10:34 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
As far as I know the only Tag that is on the 3rd gens are the Vin plates. Your spid label might be on the console lid or in the rear glove box lid.
Old Apr 14, 2006 | 12:32 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Cowl tags were used up to 84 at least. I don't know exactly when they stopped.
Old Apr 14, 2006 | 05:40 AM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
Ok that clears up one thing for me, but i still need the emissions decal and/or the info on it
Old Apr 14, 2006 | 07:51 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You should be able to goto the dealer and see if they can still get them.
Old Apr 14, 2006 | 04:17 PM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
As I stated at the beginning of the Quote they are no longer available from the dealer, like most items for the '86 model year
Old Apr 16, 2006 | 09:51 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Doc Hemi, you might already have this but here it is anyway.
GM pt no for the emissions label your looking for is 10051461.
It should have broadcast code YNB on it. I can do a national dealer search to see if anybody has one.
David
Old Apr 17, 2006 | 04:10 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Here it is.........
Puritan Pontiac-Gmc/NEW GM PARTS
Old Oct 4, 2006 | 11:06 PM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
THNX
THNX FOR THE HELP
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
