Build sheet???
Old May 14, 2006 | 07:53 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Build sheet???
i found a sheet under the seat of my bird. it has the tire size and has the vin on it and a couple of other things, could this be the build sheet?
Old May 14, 2006 | 07:56 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Maybe if you post this 5 more times someone will answer
Old May 14, 2006 | 07:57 PM
Car: 84' Trans Am
sorry my computer is messed
Old May 15, 2006 | 01:23 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Nope... keep looking.
It's some weird interior options sheet or something you found.
Old May 15, 2006 | 12:41 PM
Car: 84' Trans Am
where would u find the build sheet at?
Old May 15, 2006 | 03:26 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
I would say yes it is a build sheet. It's probably an interior build sheet. Anything used by the workers to know what was to be installed on each individual car should be considered a build sheet (line sheet at the aircraft assy plant I used to work at). By this time in production there were probably more than one. The SPID may have also taken the place of the main build sheet.
Old May 15, 2006 | 03:35 PM
Car: 84' Trans Am
do u know where they may have put the one that list the options?
Old May 15, 2006 | 03:51 PM
Car: 1990 Camaro RS
people have found it inbetween the rear GFX, in the front bumper area, under the carpet, on top of the gas tank, in door panels, on top of the headliner, etc.... it could be anywhere.
Old May 15, 2006 | 03:58 PM
Mr. TurboTA's Avatar
I just pulled small peices out of the rear hatch/plastic panel cover.
Kinda weird I thought, since there is not lots of room there. Only got a few lines, and it was glued in with the black mastic crap from glueing the glass to the metal hatch section.
George
Old May 15, 2006 | 07:35 PM
Car: 84' Trans Am
what does it ussually say on the build sheet?
Old May 15, 2006 | 08:32 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
You'll know it when you see it, and it looks like the one from my 83T/A.
Leon.
Old May 15, 2006 | 08:37 PM
Car: 84' Trans Am
where did u find yours?
Old May 15, 2006 | 08:53 PM
1tinindian's Avatar
I think it was under one of the front seats.
It's been awhile ago, so that's the best I remember.
Leon.
Old May 15, 2006 | 09:10 PM
Car: 84' Trans Am
im going to check around on it, hope no one found it before me.
Old May 17, 2006 | 11:45 PM
eastonmaxx's Avatar
I just got a 88 iroc, and the first thing i noticed was the RPO/ SPID(?) sticker adhered to the top of the airbox lid, from what i heard they are hard to locate for the most part, guess i got lucky
Old May 17, 2006 | 11:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The SPID decal is as common as dirt. Most cars still have them, except for those who have had their consoles or console lids or whatnot replaced. The build sheet is considerably more rare.
Old May 18, 2006 | 11:40 AM
1991L98G92's Avatar
"I just got a 88 iroc, and the first thing i noticed was the RPO/ SPID(?) sticker adhered to the top of the airbox lid, from what i heard they are hard to locate for the most part, guess i got lucky"
If the VIN# is correct for your car, someone removed it from either the console, or rear hatch compartment lid. That's where it should be. Yes, the spid sticker is common but worth a lot more than dirt and will verify vehicle build.
Old May 20, 2006 | 02:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
sounds like you found the build sheet
youre damned lucky
only ever found one in a third gen f body and that was in an 88 s/e
rare as hell to find
i find them all the time in the caprices and impalas and trucks and such though
always under the seat in them
good luck
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Magman
Aug 2, 2016 08:32 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Jlanz55
Sep 29, 2015 08:55 AM
