Rear end ?
Old Jun 2, 2006 | 10:36 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Rear end ?
Who knows if a stock 1987 Iroc camaro 5.0 has an open or limited slip differential?
Old Jun 2, 2006 | 10:46 PM
1992camarors's Avatar
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
Iroc's could be ordered with or without the posi traction or limited slip (same thing). The only way to know is to check the rpo sheet in your center console glove box and look for g80, that will tell you that it has a posi. Or you could jake both rear wheels in the air and then turn one wheel and if the other wheel turns the same direction that means you have a posi. And if the wheel turns in the opposite direction that means you have an open end differential. Or you could just do a burnout and see if both wheels peel.
Old Jun 2, 2006 | 10:51 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
It's only because I didn't think you could tell if a car has limited slip or open because I thought with limted slip only one wheel spins first and then the other kicks in.
Old Jun 2, 2006 | 11:21 PM
Engine: 305 TBI
Thats exactly what a Limited slip or posi does. When one wheel spins the other with lock up and give you the traction needed to lower your 0-60 times and e.t.'s.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
