I thought I knew about dash pads???
Old Aug 11, 2006 | 08:05 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Can anyone enlighten me on what this is, I have never seen a Camaro dash pad like this
eBay Motors: 82-92 camaro dash pad very clean (item 330015285142 end time Aug-12-06 06:03:49 PDT)
Old Aug 11, 2006 | 08:59 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Its nothing like eather of mine. It might be a firebird dashpad. I havent realy seen those up close.
Old Aug 11, 2006 | 09:09 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have seen a ton of FB dash pads and none of them look like that
Old Aug 12, 2006 | 12:18 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
interesting, doesnt look like a 3rd gen one, or is a modified one,
hmm
wierd
Old Aug 12, 2006 | 12:27 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
firebird dashpads DO NOT have the gap in the center for the vents and DO NOT have intergrated speaker grills, the speaker grills come out. that is how you can tell the difference in crappy pictures.
i have seen a few camaro pads before, and none of them looked like that, as far back as 84 and as recent as 91 i have never seen anything like those edges before.
Old Aug 12, 2006 | 12:30 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yep
Old Aug 12, 2006 | 12:39 AM
calobs87irocz's Avatar
Car: 87 Iroc Z, 70 & 71 Camaros, 79 Z-28
Engine: 350TPI, 350, 355, 355
Transmission: 700R4, TH350, TH350, TH350
Axle/Gears: BW3.27, 4.10, 3.73, don't know yet
I asked the seller about the year and model Camaro it came off of. I'll post as soon as (if) I hear back. Of course I like the disclaimer 'please no returns i took several pictures so u can see what you're buying makesure it fits your type of camaro as some types of models might be different'. It seems to look like Cavalier from what I remember of them.
Old Aug 12, 2006 | 01:54 AM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
it look pretty close, i think most of the pictures are upside down, kind of. Looks a bit modified maybe.....
Old Aug 12, 2006 | 06:47 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
It looks like an 84. Can't really see the leading edge very well. Those speaker grills look like they just snap on. I could be wrong though. It's been awhile since I've seen the 82-84 dash pads.
Old Aug 17, 2006 | 12:16 AM
Drew's Avatar
That's not an OEM dash... It's most likely an aftermarket replacement or a cheap JCWhitney slip-over cover. The OEM dash in the fbody never had a grill in the defroster openings.
82-83 Camaro have a ridge (simulated stiching) across the front edge from left to right. Otherwise they're identical to 84-92. The 84-92 dash is just smooth at the front. Sometime between 87 and 89 the screws in the defrost vents switched from phillips head to hex head.
82-84 Firebird dash looks similar to the Camaro dash, but the speaker grills are different and the dash is more angular. Again they have the simulated stiching on the front.
85-92 Firebird dashs are smooth like the later Camaro with seperate speaker grills and different side window defrost vents.
Old Aug 17, 2006 | 12:48 AM
Sassy8722's Avatar
Car: 89 RS
Engine: 350 5.7
So, I have a 82 Berlinetta and always wondered if another third gen Camaro dashpad would fit it? I don't want to buy and and then be surprised and out of alot of money when it doesn't fit.
Old Aug 18, 2006 | 11:52 AM
Drew's Avatar
That's a good question... I would assume the standard Camaro dash would fit, but the Berlinetta is out in left field a lot of times. My best guess would be that since the 82 Berlinetta used the standard guage cluster, dash, console, radio, etc that it'd also use the standard dashpad. 84-86 with the Star Wars dash might not be the same.
Old Aug 18, 2006 | 05:40 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am almost 100% sure the 82-84 dash pads are the same for all Camaros, I am watching the sellers feedback to see what happens whtn the buyer tries to install the pad.
Old Aug 19, 2006 | 03:54 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
huzzah!! i was very happy when i saw that exact dash (different color) at the local yard today cause this has been driving me and everyone batty. it was in a cadillac believe it or not. i think it might have been an el dorado but now for the life of me i can't remember but it was from a caddy, and now that i think of it, i should have seen if it would fit in a camaro...oh well...
Old Aug 23, 2006 | 05:12 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
ALL 82-92 Dash pads are interchangeable. The first few years the edge was "squared" off rather than the 'sharper' lip on the 84 & up stye. Some of the newer dash pads also had the day-time-running light sensor mounted in them - but they will all fit any year Camaro.. ( Even our Berlinettas ! )
I know that the later style Firebird pads will not fit on the Camaro due to the center vents on the Camaro dah hosing............Anyone know if the early Firebird pads will fit on a Camaro ????
John in RI
Old Aug 23, 2006 | 08:40 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
John in RI
No they will not. 82-92 Firebird pads interchange.
Old Aug 24, 2006 | 10:37 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Looks like a Berlinetta dashpad, the one with the digital dash....those dashes were different.
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
