I found The partial VIN on the block, Now what does it mean?
Old Aug 23, 2006 | 03:56 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
Its TBF512283 I know its not the origial engine or im pretty sure. But i know the last 6 digits are somthing about the number it was made. But whats the TBF thanks
Old Aug 23, 2006 | 04:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
6 are the sequential production unit numbers
it will match the last six of the vin code of the vehicle it was installed in at the factory
this is numbers match engines to vehicles 101
real basic stuff here'
good luck
Old Aug 23, 2006 | 04:27 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
1970 TBF 350 conv/fwd cab , mil 255 C - 10 , 20 , 30
1979 TBF 350 convcab , alt , fed L LS9 165 K - 10 , 15 , 20
definitely not origianl engine lol
fwd is forward control, that is a chevy step van, see them running aorund delivering food and parts for companies often
conv is conventional cab, that is a pickup truck, normal cab
it is most likely the nice high nickel and tin content block, harder block, very common from '69-79
a real keeper, congrats
Old Aug 23, 2006 | 04:43 PM
Car: 89 Iroc
Engine: 5.7 TPI
Yea i found that too but the code on the back of the block by the bellhousing says its a 305 from 80-85 and the head code shows its a 1.84"/1.5" valves 53cc chambers for a 305 so im really confused.
Thansk the the replys tho they were quick and what i was lookin for but the numebers arnt all matchin up
code on back of block driver side by bellhousing is 14010201
Head codes are 14022601
Old Aug 23, 2006 | 05:00 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
thats odd, 80 up block if pass side oil stick
the stamping suffix code is not corect for 80-up
14010201 305 80-85 Pass, Malibu, Monte Carlo, Camaro, Nova
i cant explain the suffix stamping code problem
hmm
Old Aug 23, 2006 | 09:06 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
The 601 heads have 58cc chambers, not 53cc
Old Aug 23, 2006 | 09:13 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I suspect the TBF is not an engine suffix code. Part of the VIN? T is a check digit, B is a year code, maybe 1981, and F is the factory where the car was made, maybe Flint? Then the sequence number for the car.
Old Aug 23, 2006 | 09:46 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I've had a few sets of 601's and they measured 53 cc's when I did them. The other common 305 head with 1.84" intakes were 416's which had 58 cc heads.
Mark.
Old Aug 23, 2006 | 11:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
WRONG, they are most definatly 53cc. I cc'd mine right after I had them cleaned. 52-53cc in every chamber.
The block casting 201 is a common 305 casting, used in alot of cars, trucks, vans.
The picture is of a worked set of 601s, the chamber is 60 cc after un-shrouding.
Attached Thumbnails I found The partial VIN on the block, Now what does it mean?-fa_3.jpg   I found The partial VIN on the block, Now what does it mean?-11_3.jpg   I found The partial VIN on the block, Now what does it mean?-47_3.jpg
Old Aug 23, 2006 | 11:58 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
youre right TBF is not the suffix
correct
suffix is ending not beginning i really dont know what the hell i was thinking there,
he told me on yahoo messenger earlier today that UAW is the suffix stamping code
i cant find it though
so i dunno
but we know for sure now that its an 80 to 85 305 anyways, so.,
Old Aug 24, 2006 | 12:06 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
correct
so i dunno
TBF512283 is the partial VIN number. Look right above (closer to the head) this number on the pad. You should see another number with the suffix code at the end.
UAW is probably another Van engine from a 1981, I believe
1981 UAW 305 con. cab, a/t, A.I.R. H LE9
What are the rest of the numbers and what other parts are on it.
FWIW, since you are dealing with a similar engine to my stock engine, the original block out of my 1983 G20 had suffix code K1012UCK
1983 UCK 305 conv.cab H LE9
CD4102926 is also cast into it (partial VIN)
14010203- 4 bolt main- 1980-1986 305
3941182- Forged 3.48" stroke crank factory balanced for a 305
X-rod castings
Flattop pistons with 4 valve reliefs.
Large 8" 350 style harmonic balancer
14022601- 53 cc heads, 1.84/1.50" valves
14057056- cast-iron 4 bbl manifold with EGR
17083226- 4 bbl non CCC Q-Jet with electric choke, 1983 Chevy truck/van
Old Aug 24, 2006 | 08:53 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Whoa, a four bolt main 305 with the big balancer, that's a new one on me. Never know what you'll find in a Chevy engine. Flat top pistons with very small chamber heads. Interesting.
Old Aug 25, 2006 | 10:24 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Chevy Engine Codes
This is a site for engine code stamping. The code should have a letter designating engine build plant, 4 numbers designating month and day, and the 3 letter suffix code. Then, if a patial vin was stamped into the block, I've seen them just below this. It will look like this: T0412CKM (CKM being the suffix code). Check again, it may be real faint, or a picture of the block where the partial vin is. Give us all a look. Then when you find the suffix code you can use this site to find year and application.
Old Aug 25, 2006 | 11:06 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yeah the T is the foundry location digit
the two letters after that digit are supposed to be numbers.,
gta90
Sep 15, 2015 04:00 PM
MoJoe
Sep 15, 2015 12:50 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
